newbie: Problem with Ethernet Shield and SHT11
Hi there
I am using SHT11 sensor and is working fine
When I arduino the ethernet shield and compine the sketch of the sensor with the server example of the ethernet shield I do not get correct measurements..
can you please suggest a solution?
#include <Ethernet.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
byte ip[] = { 192, 168, 1, 177 };
Server server(1717);
#include <SHT1x.h>
// Specify data and clock connections and instantiate SHT1x object
#define dataPin 10
#define clockPin 11
SHT1x sht1x(dataPin, clockPin);
Ethernet.begin(mac, ip);
server.begin();
float temp_c;
float temp_f;
float humidity;
// Read values from the sensor
temp_c = sht1x.readTemperatureC();
temp_f = sht1x.readTemperatureF();
humidity = sht1x.readHumidity();
Client client = server.available();
if (client) {
// an http request ends with a blank line
boolean current_line_is_blank = true;
while (client.connected()) {
if (client.available()) {
char c = client.read();
// if we've gotten to the end of the line (received a newline
// character) and the line is blank, the http request has ended,
// so we can send a reply
if (c == '\n' && current_line_is_blank) {
// send a standard http response header
client.println("Content-Type: text/html");
client.println();
// output the value of each analog input pin
for (int i = 0; i < 6; i++) {
client.print("analog input ");
client.print(i);
client.print(" is ");
client.print(analogRead(i));
client.println("
client.print("Temperature: ");
client.print(temp_c, DEC);
client.print("C / ");
client.print(temp_f, DEC);
client.print("F. Humidity: ");
client.print(humidity);
client.println("%");
if (c == '\n') {
// we're starting a new line
} else if (c != '\r') {
// we've gotten a character on the current line
current_line_is_blank = false;
// give the web browser time to receive the data
delay(1);
client.stop();
#define dataPin 10
#define clockPin 11
Digital pins 10 and 11 are used by the Ethernet shield.
Thank you for your reply
