Newbie Q number 2
Hi there
Im sill in early stages of learning but getting an error on the following code
// colour mixing lamp
const int greenLEDPin = 9;
const int redLEDPin = 11;
const int blueLEDPin = 10;
const int redSensorPin = A0;
const int greenSensorPin = A1;
const int blueSensorPin = A2;
int redValue = 0;
int greenValue = 0;
int blueValue = 0;
int redSensorValue = 0;
int greenSensorValue = 0;
int blueSensorValue = 0;
  pinMode(greenLEDPin.OUTPUT);
  pinMode(redLEDPin.OUTPUT);
  pinMode(blueLEDPin.OUTPUT);
  redSensorValue = analogRead(redSensorPin);
  delay(5);
  greenSensorValue = analogRead(greenSensorPin);
  delay(5);
  blueSensorValue = analogRead(blueSensorPin);
  delay(5);
  Serial.print("Raw Sensor Values \t Red ");
  Serial.print(redSensorValue);
  Serial.print("\t Green ");
  Serial.print(greenSensorValue);
  Serial.print("\t Blue ");
  Serial.print("bluenSensorValue");
  redValue = redSensorValue/4;
  greenValue = greenSensorValue/4;
  blueValue = blueSensorValue/4;
  Serial.print("Mapped Sensor Value \t Red ");
  Serial.print(redValue);
  Serial.print(greenValue);
  Serial.print("blueValue");
  analogWrite(redLEDPin, redValue);
  analogWrite(greenLEDPin, greenValue);
  analogWrite(blueLEDPin, blueValue);
Error shows as
od_sensor.ino: In function 'void setup()':
/Users/Debstar/Downloads/Arduino-2.app/Contents/Java/hardware/arduino/avr/cores/arduino/Arduino.h:44:16: error: expected unqualified-id before numeric constant
#define OUTPUT 0x1
mood_sensor.ino:21:23: note: in expansion of macro 'OUTPUT'
#define OUTPUT 0x1
mood_sensor.ino:22:21: note: in expansion of macro 'OUTPUT'
#define OUTPUT 0x1
mood_sensor.ino:23:22: note: in expansion of macro 'OUTPUT'
Error compiling.
So i know theres a problem with line 21-23 but i copied exactly from my project book even though i thought it looked wrong - is it testing me!? ha
what does this part mean please?
#define OUTPUT 0x1
huge thanks - when i get good i promise to help back! x
Shouldn't those be commas between the arguments to pinMode rather than periods?
If you find the line(s) with a problem, you can check the syntax.
It appears that you didn't post all of your code because the first error message refers to:
#define OUTPUT 0x1
which is not in the code you posted.
The code will compile if you fix the pinMode statements.
Tom
econjack:
Make that dot a comma.
Which project book?
Just lose all the "pinMode" - they're unnecessary
