NEWBIE Question - Arduino, Mikrotik
Hi all,
i just discover Arduino and it's looking great. I'm starting some project and i need digital i/o and analog inputs and arduino is best that i can find. So i need to connect Arduino to Mikrotik router 411U (http://www.balticnetworks.com/mikrotik-routerboard-411u.html) with #G and GPS module and I do not now which Arduino board should I buy: This one: http://arduino.cc/en/Main/ArduinoBoardEthernet Or this one: http://arduino.cc/en/Main/ArduinoBoardUno plus http://arduino.cc/en/Main/ArduinoEthernetShield
I need to pass data from Arduino to router, Router is very advanced and i can program router to do everything :) Router have serial, USB and LAN connector
Thanks all.
amonra_hr: I do not now which Arduino board should I buy: This one: http://arduino.cc/en/Main/ArduinoBoardEthernet
This one is more integrated (so in theory more reliable), but you will also need a serial port adapter to program it. It cannot be programmed via. Ethernet:
http://arduino.cc/en/Main/USBSerial
amonra_hr: Or this one: http://arduino.cc/en/Main/ArduinoBoardUno plus http://arduino.cc/en/Main/ArduinoEthernetShield
That works too, and is more flexible.
Neither is really 'better', it's a matter of taste ... and price.
I use a Mikrotik RB433UAH and a Mega2560/ethernet shield combination. I get power for the Mega from the USB port AND I can set a "special-login" on the Mikrotik, and remote connect to the router with ssh with a special username, and connect to the serial I/O of the Arduino. :)
BTW, I am SurferTim on the Mikrotik site too, if you need help with that.
Add: You could not do that with the Arduino Ethernet (no USB). Only an Uno/Ethernet shield.
