Newbie question; understanding fail message.
for (int j+1; j<=numRedBlink; j=j+1; ) [
digitalWrite(redLEDPin, HIGH);
delay(redOnTime);
digitalWrite(redLEDPin, LOW);
delay(redOffTime);
digitalWrite(yellowLEDPin, HIGH);
delay(yellowOnTime);
digitalWrite(yellowLEDPin, LOW);
delay(yellowOffTime);
Keep getting error message on “for” line. “; expected before + token”.
Any info appreciated.
Don't use square brackets to enclose code statements. They are for arrays.
This won't work either. Use "=" instead of "+".
for (int j+1; ...
for (int j+1;
That is wrong. Look up the syntax of a for statement in C.
Pete
for (int j=1; j<=numRedBlink; j=j+1 ) { //removed the semicolon there, changed the [ to {
 delay(redOnTime);
 delay(redOffTime);
You have 's defining a block. That’s what curly braces do.
You had j+1 instead of j=1 (which I suspect is a typing error, not a coding error)
You had a stray semicolon at the end of the increment.
This way is a little better:
for (int j=0; j<numRedBlink; j++ )
for (int j+1; j<=numRedBlink; j=j+1 ) { //removed the semicolon there, changed the [ to {
Didn’t fix the beginning tho: int j =1;
CrossRoads:
You’re fast. I fixed it within like 20 seconds of posting it.
Not fast, just happened to see it at the right time.
Thanks everyone for responding. j+1 was the problem, changed to j=1 and all OK. Was a typing error, will be more careful in the future. Thanks again.
