I'm no expert on circuitry or the Arduino and I'm having issues with a project. I have a series of 8 LEDs all with the same ground. When the one farthest from the grounded LED is powered, every LED should light up. When the next farthest one is powered, seven of them should light up, etc. This isn't the case however, as the Nano's 5 Volts of power aren't enough to power more than two LEDs in series. Each of the eight LEDs has its own pin that is supplying it and the next LEDs with power through a diode that blocks the output pins from being used as ground.
I tried testing it from ground up. When I power the second to last LED, it and the last light up as intended. Going up to the next LED, however, doesn't light any of the three that are being powered. I've attempted to supply power to both the pin that should light up all three along with the next that should light the last two, and doing so only causes the last two to light up. I've checked it by connecting the LED third from ground to ground and it does light up when that's done.
Currently I have no clue how to get this to work without having to completely rewire everything which I don't have the time to do. If anyone can explain to me how to work around this issue or fix it somehow it would be very much appreciated!
Everything in the above statement says all eight leds are being run from the Nano's 5V
Given that it is no secret the voltage drop accross a led is in the ball park of 1.2 to 1.5Vdc, the above is not usually attempted for that reason.
If I had a 24Vdc power supply and an LM317 and a 2k trim pot , I could have them all running in no time I could dial up the voltage
until they were all bright enough, shut off the power, measure the position of the trimpot and then replace it with fixed resistors.
Speaking of resistors, I don't see anything in the above about current limiting resistors or their value.
