newbie: series of lightbulbs for light kinematics science/art project
For an upcoming end of the year physics project, a group of friends and I decided to take on the task of creating a sort of interactive science art piece, though we are fairly new to the world of arduino engineering.
The ideas is: to create a series of about 10 or so incandescent light bulbs (really for aesthetic appeal, though do let me know if LEDs would be more feasible) in a row on a wooden panel. A light flick onto the first lightbulb would release a pulse through each light bulb, only one bulb lit at a time, current flowing from the first lightbulb to the next. The hope is to have some sort of piezoelectric sensor hooked up to the first bulb, so that the strength of the flick determines how quickly the current is passed onward to each bulb, how much voltage the series would initially start off with, and how quickly the current diminishes to zero to leave no more light. (Think of it as using light to mimic an object's motion sliding across a surface with friction.)
As of now, I think I would use transistors to limit to which bulb the voltage reaches. Though for the rest of the project, a bit of guidance would be of much appreciated help. My group is ready to immerse ourself in the project and learn as much as we can (which is why we decided to take on the task — to force ourselves to learn).
Any help on how exactly to set things up so that the arduino processes both the input from the piezoelectric, as well as managing and varying the voltage applied to each bulb at different time intervals? Are there any other processors/big pieces of tech we'll need (excluding the obvious like wires and such)? Anything to be wary of with the lightbulbs' wattage and how much voltage the arduino can handle?
I apologize for how new I am to this, but thank you so, so much ahead of time for your help! :slight_smile:
Oh, and is there a specific type of arduino that would be best for our usage? I've been looking at the Arduino Uno.
LEDs would be easier but if you want the look of incandescent filaments, it's expensive to simulate that with LEDs. If the bulbs are frosted then LEDs will be indistinguishable.
How many lights? Does the Uno have enough PWM outputs for your plan? You need the PWM capability on every light. For large numbers 20-20,000 you would use separate driver chips for the LEDs.
How big are these lights? Do they light up the room with 200W of incandescent? Switching that amount of power requires transistors or specialised driver chips.
Sensing the strength of the flick might be problematic but piezo is the way to go there. You may need some analog circuitry to manage that input.
I would look at using a WS2812b LED strip to do this. That could produce the visual effect so much easier than what you are proposing.
