Ive found many other threads on millis but any that are similar to my situation are cut short or don't have a clear how they found the solution.. Ive tried for the past couple days and its to the point now Im going backwards with learning.... yes you read that correctly lol forgetting things I thought I knew..
My head literally hurts right now Ill try finding some code I had saved but I started to many to know where I left off at the moment.
What Im trying to do...
When the Button is pressed turn on a relay for 100ms then back off ... the button might be held for half a second or more but only need the relay to come on for 100ms
I have a understanding of State Change Detection. I have a code that does what I need but just cant get the millis function worked into it properly... any help or information where I can look/read more Id greatly appreciate it!!
Set up the timer so it's continually reset {timerNow = millis();} as long as a boolean timerFlag is false.
Use the switch-became-pressed state change to set timerFlag true to allow the timer to run.
Now, combine the flag and the timer status to control the relay - that is, if the flag is set *and * the timer hasn't run out, turn the relay on, else relay off.
When the timer reaches preset, set timerFlag back to false. Timer is again reset and the logic waits for the next button press.
hobbyist I feel like I was so close with some of my attemps!
I know Ive wrote this very same code and just had it in the wrong area!!
I don't know why millis is giving me such a tough time understanding.. Think I might me to focused on my project.. Thanks I greatly appreciate it, Im going to try some other time based code so I can fully grasp the function..
if (millis() - previousMillis >= RELAY_ON_INTERVAL) {
digitalWrite(relay, LOW); // turn OFF relay after 100 milliseconds
I will study this button library
I try to use this forum as a last resort but I was really running out of ideas and just bumming my self out!
Thanks again!
I'm going to try some other time based code so I can fully grasp the function..
It might help your understanding if you used the words "startTime" or "pressedTime" for the time stamp value when the button is pressed instead of "previousMillis".
Here's an example of using the boolean timing variable (as described by dougp) to pick up the state change when the button becomes pressed.
IoT_hobbyist:
Thank you @12Stepper for correcting my grammar mistake.
It wasn't a grammar mistake, but you knew that: you attitude as shown by the continued use of the word "should" as opposed to "could" or "may" is that your way is the only way, and it's not.
