These are the pins im using so far
int ledPin0 = 0; // + LED connected to digital pins 0 → 8
int ledPin1 = 1;
int ledPin2 = 2;
int ledPin3 = 3;
int ledPin4 = 4;
int ledPin5 = 5;
int ledPin6 = 6;
int ledPin7 = 7;
int ledPin8 = 8;
in the code from the link you can download the files.
the code reads…
The hardware for this project is as follows:
pin 1 connects to serial port programming circuitry
pin 2 PD0 - ground for top plane of 3x3 LEDs
pin 3 PD1 - ground for middle plane of 3x3 LEDs
pin 6 PD2 - ground for bottom plane of 3x3 LEDs
pin 7 PD3 - +V for lower-left LED of each plane
pin 10 ground
pin 12 PB0 - +V for upper-right LED of each plane
pin 13 PB1 - +V for upper-middle LED of each plane
pin 14 PB2 - +V for upper-right LED of each plane
pin 15 PB3 - +V for middle-right LED of each plane
pin 16 PB4 - +V for midle-middle LED of each plane
pin 17 PB5 - +V for middle-right LED of each plane – also connects to serial port programming circuitry
pin 18 PB6 - +V for lower-right LED of each plane – also connects to serial port programming circuitry
pin 19 PB7 - +V for lower-middle LED of each plane – also connects to serial port programming circuitry
pin 20 +3v
All other pins are unused
and it has some include files but i cant find them… #include <avr/io.h> // this contains all the IO port definitions #include <avr/interrupt.h> // definitions for interrupts #include <avr/sleep.h> // definitions for power-down modes #include <avr/pgmspace.h> // definitions or keeping constants in program memory
can you please send me in the right direction
many thanks jason
This is just a wild guess, as I’m a rank newbie, but I believe that setting an output pin LOW connects it to ground.
So, if you’re scanning through the planes of LEDs:
set all the ground outputs HIGH
set the individual +V pins high for whichever LEDs you want to light for a given plane
set the relevant ground pin LOW (all the selected LEDs light at this point)
repeat as desired (being sure to set all the ground pins HIGH first, so the next row doesn’t light up with the currently-selected LEDs), selecting a new ground pin to select a different plane
pinMode(ledPin11, HIGH); // Turn on ground
** digitalWrite(ledPin0, HIGH); // sets the LEDS on**
** delay(250); // waits for a second**
** digitalWrite(ledPin0, LOW); // sets the LED off**
** delay(20); // waits for a second**
** pinMode(ledPin11, LOW); // Turn off ground**
then just change between your ground pins
im still playing so i may find a better way to tidy up the code
