And don't forget that if that same 12V is supposed to supply the 5V to the coil, you'll need to drop it to 5V for that too, but with a dc-dc voltage converter. Or have you got 5V handy for the coil?
By the way, when you say "2 channel relay" do you mean just a standalone relay or a "relay on a board" module with a control input?
If the former, you'll need a transistor to do the switching of the coil 5V with the Arduino i/o to its base. If the latter, you switch the relay with an Arduino i/o pin and the board has electronics to do that.
1- no problem in reducing the 12V to 5V as a sensing input for the arduino
2- the relays are relay on a board" module with a control input... thus they can be connected directly to arduino outputs
3- I have no experience with coding languages
.. Is there any available coding example similar to mine so that I can elaborate accordingly? I tried looking here to no avail...
Any help in this respect is highly appreciated. thx in advance
I used minibloq application to come out with the following code parameters.... did i do it right? am i on the right track?
D0 & D1 are used to sense the 5V (converted from 12V through a voltage divider using a 2.2k and a 1k resistors would keep my input voltage under 5 for all the way to 16v source)
D14 & D15 are the digital outputs that should trigger the relays 1 & 2 accordingly for the below specified values in milli-seconds. right?
