newbie trouble with a nano and L298n
Hi everyone, hopefully I am improving with my ability to post....not so much on the coding but I'm trying,,,,
It seems like it should be pretty simple to push a button and make a motor turn but it's not working and I'm a bit stuck. would appreciate a point in the right direction....here is the sketch:
//////arduino nano with L298n
//////2 push button with 2 motor
//////push for on, release for off
//////potentiameter speed control
////push button A pin d6
////push button B pin d5
////motor 1 enable pin d10
////motor 1 int 1 pin d7
////motor 1 int 2 pin d8
////motor 2 enable pin d9
////motor 2 int 3 pin d2
////motor 2 int 4 pin d4
//potentiometer pin a1
#define enA 10
#define in1 7
#define in2 8
#define buttonA 6
#define enB 9
#define in3 2
#define in4 4
#define buttonB 5
// Speed control potentiometers
int SpeedControl1 = A1;
int SpeedControl2 = A1;
// Motor Speed Values - Start at zero
int MotorSpeed1 = 0;
int MotorSpeed2 = 0;
  pinMode(enA, OUTPUT);
  pinMode(in1, OUTPUT);
  pinMode(in2, OUTPUT);
  pinMode(buttonA, INPUT);
  pinMode(enB, OUTPUT);
  pinMode(in3, OUTPUT);
  pinMode(in4, OUTPUT);
  pinMode(buttonB, INPUT);
  // Set Motor A forward
  digitalWrite(in1, LOW);
  digitalWrite(in2, LOW);
  // If button is pressed - turn motor on
  if (buttonA == true) {
    digitalWrite(in1, HIGH);
    delay(20);
    // Set Motor B forward
    digitalWrite(in3, LOW);
    digitalWrite(in4, LOW);
    if (buttonB == true) {
      delay(20);
      // Read the values from the potentiometers
      MotorSpeed1 = analogRead(SpeedControl1);
      MotorSpeed2 = analogRead(SpeedControl2);
      // Convert to range of 0-255
      MotorSpeed1 = map(MotorSpeed1, 0, 1023, 0, 255);
      MotorSpeed2 = map(MotorSpeed2, 0, 1023, 0, 255);
      // Adjust to prevent "buzzing" at very low speed
      if (MotorSpeed1 < 8)MotorSpeed1 = 0;
      if (MotorSpeed2 < 8)MotorSpeed2 = 0;
      // Set the motor speeds
      analogWrite(enA, MotorSpeed1);
      analogWrite(enB, MotorSpeed2);
Comparing buttonA or buttonB which are pin numbers won't do anything useful. Probably you meant digitalRead() of buttonA or buttonB.
Steve
slipstick:
Steve
Thank you for the reply, I realized i messed up there and changed it to this:
#define enA 10
#define in1 7
#define in2 8
const int buttonPinA = 6;
#define enB 9
#define in3 2
#define in4 4
const int buttonPinB = 5;
// variables will change:
int buttonStateA = 0;         // variable for reading the pushbutton status
int buttonStateB = 0;         // variable for reading the pushbutton status
  pinMode(buttonPinA, INPUT);
  pinMode(buttonPinB, INPUT);
  // read the state of the pushbutton value:
  buttonStateA = digitalRead(buttonPinA);
  if (buttonStateA == HIGH) {
    // turn LED on:
    delay(20);
    // turn motor off:
  } digitalWrite(in1, LOW);
  delay(20);
  buttonStateB = digitalRead(buttonPinB);
  if (buttonStateB == HIGH) {
    // turn LED on:
    digitalWrite(in3, HIGH);
    delay(20);
    // turn motor off:
  } digitalWrite(in3, LOW);
  delay(20);
I'm still struggling with making it work correctly. Can this be done with just 1 potentiometer?
Please take a moment to tell us what goes wrong.
jremington:
the Motor B is running when the power turned on and has no reaction to the buttonB.
Motor A only runs when you press the buttonA like it should be.
Both seem have speed cotrol from the one potentiometer.
Here is the code right now, I tried to fix some comments so it was easier to understand
#define enA 10
#define in1 7
#define in2 8
#define enB 9
#define in3 2
#define in4 4
    // turn motor A on:
    delay(20);
    // turn motor A off:
  delay(20);
    // turn Motor B on:
    delay(20);
    // turn Motor B off:
  delay(20);
This is so strange. Please look at the picture. If I remove the purple wire from the breadboard, nothing changes and the motor still turns without pushing the button. If I remove that same purple wire from the nano, the motor stops turning and of course still doesn't work with the button.....what on earth could be causing this??
OP picture:
It looks like the purple wire is connected to VCC (wrong). If you disconnect it, it is floating and the input is unpredictable (also wrong).
aarg:
OP picture:
what does that mean?
It means you buggered up the wiring.
@aarg was showing you how to post your picture properly. Image posting guide.
OP means, "original poster"... you.
aarg:
Haha! Thank you, fixed it...all good!
jremington:
Thank for the link!
aarg:
Appreciate the education folks, ....slowly but surely, I'll get there....
