I am trying to get to grips with Arduino. I am using a Mac running 10.14.4.
My Arduino UNO works so I bought some clones. A Pro mini and a Nano. When I connect them and try to upload I get:
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
I have googled this but there does not seem to be a definative answer and most people have windows so they always talk about installing drivers.
Also there is talk about flashing firmware. When I buy a new board, do I have to do this?
I am having problems connecting to my Pro mini and Nano with my Macbook.
I have a UNO original which connects ok.
I get this message with both Nano and ProMini: (tried different cables)
I saw on the Project hub “Prgramming the Arduino Pro Mini via the UNO.
I did this and hey presto, the Pro Mini connects.
Question 1 : Why is this happening?
Question 2: Can I prgramm all boards like this?
Question 3: Anyone know a better solution?
Herrid:
For the Nano, select Tools > Processor > ATmega328P (Old Bootloader) and then try uploading again.
Herrid:
I can now see that the tutorial is about turning the Uno into a USB to TTL serial adapter for the Pro Mini.
What are you using for a USB to TTL serial adapter when you get the upload error? How is it wired to the Pro Mini?
Herrid:
Well, in the Arduino world, "uploading a sketch" is just another term for flashing firmware. Perhaps you're talking about burning the bootloader? If so, that's definitely not necessary. The fact that you can upload to your Pro Mini using the Uno in the way shown in that tutorial proves that the bootloader on your Pro Mini is working fine.
That's your problem. You need to make the connections RX-TX, TX-RX. The reason is that RX stands for "receive" and TX stands for "transmit". The reason why the RX-RX, TX-TX connection works on the Uno is because the RX and TX pins are labeled as they connect to the ATmega328P microcontroller which is normally on the Uno. However, you are not using the ATmega328P chip. You are connecting the USB to TTL serial adapter chip on the Uno (ATmega16U2 on the official and clone Uno, CH340 on the derivative Unos) to the Pro Mini. That USB to TTL serial adapter chip is connected to the ATmega328P on the Uno with an RX-TX, TX-RX connection. So your RX-RX, TX-TX connection to the Uno is really a RX-TX, TX-RX connection to the USB to TTL serial adapter.
