Newbie's Analog input problems - please help
Hello folks,
I have an Arduino Diecimila (A Freeduino equivalent, actually), and I am having a lot of trouble getting a stable analog input.
The drawing below shows 2 experiments I did:
http://picasaweb.google.com/glman74/NutsAboutElectronics#5354455408700776946
I am just printing to the serial port and using the serial monitor to see the values.
int val = 0;
  val = analogRead(0);
  Serial.println(val);
  delay(100);
With the 10K Pot, I am getting values in the range 300 to 700. The values are never steady.
With LM 35, the multimeter shows a reading of 240 mV at the center pin, which I am guessing corresponds to 24 degrees Celsius, which seems right for my room. But the analog values being printed are close to 400 range, which seems wrong by a factor of 10.
Why I am I not able to get values in the 0-1023 range with the pot? I'd appreciate any help with this as I have been stuck with this for several weeks.
Could this be due to some interference with the USB connection to the laptop? Also, when I put my hand close to the board, the analog values fluctuate wildly.
Based on what I read online, I tried a few ideas, none of which worked:
  • Switched to a separate 9V supply.
  • Added a 47 K pull down resistor at analog pin 0.
  • Tried averaging values.
  • Pulled out most of my remaining hair. ;-)
I'd appreciate any help with this.
Best Regards
MV
You don't need or want a pull down resistor on the analog input. Try connecting to a different analog pin. Too much voltage (more than 5 volts) can damage the input circuit and if this had happened you would get the symptoms you are seeing.
Thanks for your response.
On a whim, I tried an analogRead() on all pins. I was amazed to see correct results on pin 5 - i. The order of analog pins printed on the (Freeduino) board is wrong (reversed). Everything works now. I've notified the manufacturer and they have agreed to correct the mistake.
