ok so firstly let me make it clear that i am aware that the code is missing a lot before it will work.... this is the first attempt at writing anything from scratch so forgive me... i guess what I'm looking for from you guys is more direction? .... iv spent the last 2 weeks reading and re-reading websites etc. to try and get a handle on things but its very difficult as I'm sure you're all aware... i believe the sketch is at very least legible, enough so that it should be clear what I'm trying to accomplish.... just looking for help completing the parts i cant figure out such as button pushes, how to play a melody over a speaker and temp readings using 2 types of sensors.....
keep in mind we all have to start somewhere! lol
// hardware I’m using
// arduino mega
// 3x ds18b20
// 1 x SainSmart MAX31855 Module + K Type Thermocouple Thermocouple Sensor For Arduino
// Frentaly® IIC/I2C/TWI 2004 Serial Blue Backlight LCD Module for Arduino UNO R3 MEGA2560 20 X 4, 2004
// all momentary push buttons
//motorized ball valve open when power applied, closed when power removed
#include <OneWire.h>
#include <DallasTemperature.h>
int Ds = 3;
int GValve = 4;
int Pump = 5;
int Spark = 6;
int Pwr = 7;
int Safe = 8; //thermocoupler
int AlmRly = 9;
int Spkr = 10;
int TempUp = 11;
int TempDn = 12;
float InTemp = //1st ds18b20 temp
float OutTemp = // 2nd ds18b20 temp
float TubTemp = // 3rd ds18b20 temp
float Avr = (InTemp + TubTemp) / 2
float TempHi = 105 // pin 11 and 12 should influence this number up or down by 1 number at a time.
unsigned float TempLo = 100
int LowSense = 100 //ferinheight
int Heater = //thermocouple temp
pinMode(Ds, INPUT);
pinMode(GValve, OUTPUT);
pinMode(Pump, OUTPUT);
pinMode(Spark, OUTPUT);
pinMode(Pwr, INPUT);
pinMode(Safe, INPUT);
pinMode(AlmRly, OUTPUT);
pinMode(Spkr, OUTPUT);
pinMode(TempUp, INPUT);
pinMode(TempDn, INPUT);
short press Pwr
digitalWrite (Pump, HIGH);
short press again
digitalWrite (Pump, LOW);
long press Pwr,
delay(30000);
digitalWrite (Spark, HIGH);
digitalWrite (GValve, HIGH);
delay(10000);
digitalWrite (Spark, LOW);
delay (10000);
if (Safe > Heater)
digitalWrite (GValve && Pump, HIGH);
digitalWrite (Gvalve, LOW);
digitalWrite (AlmRly, HUGH);
Spkr plays tone for (10000) //any generic beeps or simple melody
long press Pwr again,
digitalWrite (GValve, LOW);
delay (6000);
check and display temps, InTemp, OutTemp, TubTemp and eta till hot.base eta on speed of rise over last 5 minutes and known desired temp //in ferinheight on 20x4 serial enabled lcd
if (Avr => Temp && Safe > LowSense)
delay(60000);
delay (10000);
if (Safe > LowSense)
//continue with previous statement
digitalWrite (AlmRly, HIGH);
Spkr plays tone for 10 seconds //any generic beeps or simple melody
continue monitering temps…..
if (Avr <= TempLo)
delay (30000);
delay(10000);
delay (10000);
