Newby help: change behavior based on power supply
Hi all - I have some decent experience with Arduino, but wouldn't call myself an expert, so need y'alls help.
I'm looking to use arduino as the core for an escape room type puzzle. Part of the puzzle requires the solver to use one of two different power supplies, connected to a "radio control board" through two aligator clamps, but I need the arduino program to do something different based on the power supply connected. Type of power supply can be adjusted, just need to figure out what parameter of the power supplies can be used to create two seperate actions in the program.
Any thoughts on how to accomplish this?
Voltage.
Use a keyed plug.
That sounds like an interesting project that could be a lot of fun! However, please keep in mind that we are not a free design or code-writing service. We’re more than happy to help with your design or code, but we need you to make an initial attempt. Please design and write your code, then post it along with an explanation of what’s not working properly. There is also a for hire section if you want to pay for it.
  1. Show Your Work First: Before asking for assistance, make an attempt to design or write the code yourself. Share your work along with details about what isn’t working.
  2. Provide Clear Documentation: Since we can’t see your project, share an annotated schematic (best) or a clear drawing of your setup. Pictures are welcome, but avoid using Fritzing diagrams as they are wiring diagrams, not schematics, and are not ideal for troubleshooting.
  3. Include Technical Details: If there is specific hardware involved, include links to technical information. There are often many versions of similar components, so precise details are essential.
  4. Reference Resources: For additional help, check out useful links and tutorials: Useful Links on Arduino Forum.
I assume that one supply solves the puzzle and the other does not, is that correct?
