Newby met problemen.
Bij het installeren van firmware in mijn vertex 8400 3D printer.
Arduino: 1.8.4 (Windows 7), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
In file included from sketch\Marlin.h:23:0,
                 from sketch\thermistortables.h:4,
                 from sketch\Configuration.h:733,
                 from C:\Users\baba\Desktop\Vertex-Firmware-H1-master\vertex-m1-v1.4-h1\Marlin\Marlin.pde:33:
sketch\pins.h:401:0: warning: "FAN_PIN" redefined
     #define FAN_PIN            8
sketch\pins.h:396:0: note: this is the location of the previous definition
     #define FAN_PIN            4 // IO pin. Buffer needed
sketch\pins.h:419:0: warning: "HEATER_2_PIN" redefined
     #define HEATER_2_PIN       6   //BED
sketch\pins.h:414:0: note: this is the location of the previous definition
   #define HEATER_2_PIN       -1
sketch\pins.h:459:0: warning: "BEEPER" redefined
         #define BEEPER -1   // Beeper on AUX-4
sketch\pins.h:432:0: note: this is the location of the previous definition
       #define BEEPER 33   // Beeper on AUX-4
sketch\pins.h:461:0: warning: "LCD_PINS_RS" redefined
         #define LCD_PINS_RS 27
sketch\pins.h:434:0: note: this is the location of the previous definition
       #define LCD_PINS_RS 16
sketch\pins.h:462:0: warning: "LCD_PINS_ENABLE" redefined
         #define LCD_PINS_ENABLE 29
sketch\pins.h:435:0: note: this is the location of the previous definition
       #define LCD_PINS_ENABLE 17
sketch\pins.h:463:0: warning: "LCD_PINS_D4" redefined
         #define LCD_PINS_D4 37
sketch\pins.h:436:0: note: this is the location of the previous definition
       #define LCD_PINS_D4 23
sketch\pins.h:464:0: warning: "LCD_PINS_D5" redefined
         #define LCD_PINS_D5 35
sketch\pins.h:437:0: note: this is the location of the previous definition
       #define LCD_PINS_D5 25
sketch\pins.h:465:0: warning: "LCD_PINS_D6" redefined
         #define LCD_PINS_D6 33
sketch\pins.h:438:0: note: this is the location of the previous definition
       #define LCD_PINS_D6 27
sketch\pins.h:466:0: warning: "LCD_PINS_D7" redefined
         #define LCD_PINS_D7 31
sketch\pins.h:439:0: note: this is the location of the previous definition
       #define LCD_PINS_D7 29
sketch\pins.h:469:0: warning: "BTN_EN1" redefined
         #define BTN_EN1 17
sketch\pins.h:442:0: note: this is the location of the previous definition
       #define BTN_EN1 37
sketch\pins.h:470:0: warning: "BTN_EN2" redefined
         #define BTN_EN2 16
sketch\pins.h:443:0: note: this is the location of the previous definition
       #define BTN_EN2 35
sketch\pins.h:471:0: warning: "BTN_ENC" redefined
         #define BTN_ENC 23  //the click
sketch\pins.h:444:0: note: this is the location of the previous definition
       #define BTN_ENC 31  //the click
                 from sketch\Marlin_main.cpp:30:
     #define FAN_PIN            8
         #define BTN_EN1 17
       #define BTN_EN1 37
         #define BTN_EN2 16
       #define BTN_EN2 35
sketch\Marlin_main.cpp:2119:36: warning: invalid suffix on literal; C++11 requires a space between literal and string macro [-Wliteral-suffix]
         LCD_MESSAGEPGM(MACHINE_NAME" "MSG_OFF".");
In file included from sketch\SdFile.h:27:0,
                 from sketch\cardreader.h:8,
                 from sketch\Marlin_main.cpp:44:
SdBaseFile.h:38: error: using typedef-name 'fpos_t' after 'struct'
 struct fpos_t {
In file included from sketch\Marlin.h:10:0,
c:\program files (x86)\arduino\hardware\tools\avr\avr\include\stdio.h:950:33: note: 'fpos_t' has a previous declaration here
 __extension__ typedef long long fpos_t;
exit status 1
option enabled in File -> Preferences.
Iemand tips om dit euvel te verhelpen?
Ik denk dat je een marlin.ino en een marlin.pde ertussen heb staan. Die pde dan verwijderen of renamen naar .xxx oid
Heb de naam gewijzigd maar dit helpt niet. Ik krijg dezelfde foutmelding.
En als je hem eruit gooit?
Ook geprobeerd...
Post de hele sketch om te zien of we je probleem kunnen reproduceren?
Marlin firmware zijn een stuk 20 bestanden. Maak er eens een zipfile van die hele folder en stuur die naar nico punt verduin at ziggo punt nl. Kijk ik wel ff
