I am using the NewPing library with the 4-pin Ultrasonic HC-SR04. I wish to read the distance data into Maxuino using Firmata. Is there a simple way to integrate the NewPing code into the StandardFirmata sketch and hence read the values as integer values in Maxuino (to ultimately control an audio parameter)?
I am a Max user with limited C programming knowledge.
#define TRIGGER_PIN 12 // Arduino pin tied to trigger pin on the ultrasonic sensor. #define ECHO_PIN 11 // Arduino pin tied to echo pin on the ultrasonic sensor. #define MAX_DISTANCE 200 // Maximum distance we want to ping for (in centimeters). Maximum sensor distance is rated at 400-500cm.
NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE); // NewPing setup of pins and maximum distance.
Serial.begin(115200); // Open serial monitor at 115200 baud to see ping results.
delay(50); // Wait 50ms between pings (about 20 pings/sec). 29ms should be the shortest delay between pings.
unsigned int uS = sonar.ping(); // Send ping, get ping time in microseconds (uS).
Serial.print("Ping: ");
Serial.print(uS / US_ROUNDTRIP_CM); // Convert ping time to distance in cm and print result (0 = outside set distance range)
Serial.println("cm");
The simple answer is no. There is no need to stupify the Arduino by using Firmata. If the PC application thinks it needs to, the PC application deserves a rim shot into the bit bucket.
