NewPing.h - timer_ms(frequency, function) - Wrong values
Hello,
The original example Sketch from NewPing Libary = correct values
But the sketch with timer_ms method = wrong values
the original Code:
include <NewPing.h>
#define TRIGGER_PIN  18
#define ECHO_PIN     19
#define MAX_DISTANCE 200
NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE);
  delay(50);
  int uS = sonar.ping();
  Serial.print("Ping: ");
  Serial.print(uS / US_ROUNDTRIP_CM);
  Serial.println("cm");
Here i got 80cm
The other Code:
#include <NewPing.h>
#define ECHO_PIN     19
void int_messung()
  NewPing::timer_ms(50, int_messung);
here i got 7 cm
The same result I get when I us the Libary TimerOne.h
Can someone help me?
Joe
I suspect that the problem is using Serial.print() inside an ISR. Each output byte takes about 1 ms at 9600 baud.
