Newping library into normal library
I am trying to simulate something on tinkercad, but the library <NewPing.h> is not available on Tinkercad. I wrote my code based on that library. Is there a way to work around in and convert my values into commands that will work on Tinkercad?
This is the code that I have on NewPing that I need to convert it into regular code. Help!!!
#include <NewPing.h>
#define SONAR_NUM 2
#define MAX_DISTANCE 50
NewPing sonar[SONAR_NUM] = {
NewPing(4, 5, MAX_DISTANCE), // trigger, echo, max distance.
NewPing(8, 9, MAX_DISTANCE)
Serial.println("-----------------------");
Serial.print(“SENSOR PING AB = “);
float pingSensor1=sonar[0].ping_median(6);
//float pingSensor1=sonar[0].ping();
Serial.print(pingSensor1);
Serial.println(” us”);
Serial.print(“SENSOR PING BA = “);
float pingSensor2=sonar[1].ping_median(6);
//float pingSensor2=sonar[1].ping();
Serial.print(pingSensor2);
//https://wikimedia.org/api/rest_v1/media/math/render/svg/fef32b5ef4e6b21aa4a76e1af24085f5f1b9f778
float AirSpeed=(0.3/2)((pingSensor1/1000000-pingSensor2/1000000)/(pingSensor1/1000000pingSensor2/1000000));
float error=100-(pingSensor2/pingSensor1)*100;
Serial.print(“Error = “);
Serial.print(error);
Serial.println(”%”);
Serial.print(“Air flow =”);
Serial.print(AirSpeed);
Serial.println(“m/s”);
