NewSoftSerial "write"?
I have the following code that worked with the Serial.write to my serial display:
This is a portion of the code
Serial.begin(9600);//
strcpy_P(buffer, (char*)pgm_read_word(&(string_table[instrument]))); // Necessary casts and dereferencing, just copy.
char buffer[30];    // make sure this is large enough for the largest string it must hold
Serial.write(buffer); //works on standard serial port
//Newsoft serial code
#include <NewSoftSerial.h>
Display.begin(9600);
NewSoftSerial Display(11,10); //Soft TX on 10, Idon't use RX in this code
Display.write(buffer); //doesn't work
//Display.print("test"); works
What do I need to do to get NewSoftSerial to work?
You mean it doesn't compile? How about the error message? Was it:
In file included from sketch_jan19a.cpp:2:
/Users/nick/Documents/Arduino/libraries/NewSoftSerial/NewSoftSerial.h:71: error: conflicting return type specified for 'virtual void NewSoftSerial::write(uint8_t)'
/Applications/Arduino 1.0.app/Contents/Resources/Java/hardware/arduino/cores/arduino/Print.h:48: error:   overriding 'virtual size_t Print::write(uint8_t)'
Have you downloaded the latest NewSoftSerial? (I haven't).
I beleive I have the latest NewSoftSerial
Error is
C:\Users\mike\Desktop\arduino-0022\libraries\NewSoftSerial/NewSoftSerial.h: In function 'void loop()': C:\Users\mike\Desktop\arduino-0022\libraries\NewSoftSerial/NewSoftSerial.h:71: error: 'virtual void NewSoftSerial::write(uint8_t)' is private string:382: error: within this context string:382: error: invalid conversion from 'char*' to 'uint8_t' string:382: error: initializing argument 1 of 'virtual void NewSoftSerial::write(uint8_t)'
Try "print" instead of "write".
You are trying to use NewSoftSerial with 1.0. For 1.0, NewSoftSerial is delivered with the IDE, as SoftwareSerial, and the write() method is now public.
