Nextion.available() doesn't work
Hello all,
When clicking buttons, on the second page of the screen, nextion.available() is false all the time
Program code:
#include <DHT11.h>
#include <SoftwareSerial.h>
#include <Nextion.h>
DHT11 dht11(2);
intValue;
StringTosend;
String data; // variable for storing data
SoftwareSerial nextion(8, 9); // Nextion TX to pin 8 and RX to pin 9 of Arduino
Nextion myNextion(nextion, 9600); //create a Nextion object named myNextion using the nextion serial port @ 9600bps
void SendAdd(int id, int NumGraf, int val)
   if (NumGraf == 0) Value = map(val,0,125,0,255);
   if (NumGraf == 1) Value = map(val,0,100,0,255);
   Tosend = "add";
   Tosend += id;
   Tosend += ",";
   Tosend += NumGraf;
   Tosend += ",";
   Tosend += Value;
   nextion.print(Tosend);
   nextion.write(0xff);
     nextion.begin(9600);
     myNextion.init();
     pinMode(LED_BUILTIN, OUTPUT);
     pinMode(3, OUTPUT);
     digitalWrite(3, 1);
     int temperature = 0;
     int humidity = 0;
     int result = dht11.readTemperatureHumidity(temperature, humidity);
     //update temperature and humidity text
     myNextion.setComponentText("page0.t0", String(temperature));
     myNextion.setComponentText("page0.t1", String(humidity));
     //update temperature and humidity graphs
     SendAdd(5,0, temperature);
     SendAdd(5,1, humidity);
     // wait for data from the display
     if (nextion.available())
       char inc;
       inc = nextion.read();
       data += inc;
       Serial.println("nextion.available");
       if (inc == 0x0A) //end of command
         // if 'on' came
         if (data.indexOf("on") >= 0)
            digitalWrite(LED_BUILTIN, 1);
            digitalWrite(3, 0);
            data = "";
            Serial.println("on");
         if 'off' came
         if (data.indexOf("off") >= 0)
            digitalWrite(LED_BUILTIN, 0);
            digitalWrite(3, 1);
            data = "";
            Serial.println("off");
If excluded, the code is:
    int humidity = 0;
Then nextion.available() works and returns true.
Tell me how to solve this problem. So that the graphs would be drawn on the first page and there would be a reaction to pressing buttons on the second page.
Changed the button click interception code. But, unfortunately, button presses are still not intercepted if the graph is simultaneously drawn:
    int humidity = 0;
    String message = myNextion.listen();
    if (message == "65 1 2 1 ffff ffff ffff") //65 01 02 01 FF FF FF
       Serial.println("Green button");
       digitalWrite(3, 0);
       data = "";
    if (message == "65 1 3 1 ffff ffff ffff") //65 01 03 01 FF FF FF
       Serial.println("Red button");
       digitalWrite(3, 1);
       data = "";
