Greetings
I struggle with a project and so far, this forum could help me indirectly in many ways. For this particular problem, i sadly have not found a solution yet, that's why I'm asking for your help directly.
I use a Nextion Enhanced together with an Arduino Uno. The goal is to send all second some sensor values to the Nextion, as well as using the Nextion to give some thresholds and to define a name for the logfile. More has to follow, but is not relevant for this problem.
The thresholds can be changed with the qwerty keyboard on the Nextion. When i'm done, i can send the data to the Arduino with an update button that prints the values.
One button sets the new thresholds, one sets the new logfile name, and one let me toggle the onboard led.
My problem is that as soon as i open the Nextion keyboard, or when i press a button repeatedly , the arduino freezes. While the Nextion still works, the arduino does nothing. The led wont toggle, the data which is sent all second will not be send, and the textfields for those datapoints will show "newtxt".
If i look at the message received at those moments, it just shows some rectangles in the serial monitor. I wasn't able to find the problem with the nextion editor debug as well, but i use this software only since 4 days and i'm still unfamiliar with it.
I guess it is a problem with the serial communication, but i'm not sure...
I truly hope you are able to help me, and thank you kindly for your support.
Best regards
Just some random mad scientist
Here is my code so far:
Arduino to Nextion Display Boring Holiday Project
July / August 2024
Hardware:
Arduino Uno Rev.3
Nextion Display NX4832K035-010
Enhanced Series, 3.5”, 480*320 pixels
#include <SoftwareSerial.h> //Include the library
SoftwareSerial Serial2(10, 11); // RX, TX
byte f_goal = 0; // 0-255, force goal
float f_LC = 0.0; // force load cell
float displ = 0.0; // displacement
word rt_goal = 0; // 0-65535, runtime goal
bool run = false;
const word rate = 1000; // in ms
unsigned long rt_last = 0; // 0-4'294'967'295 -> ca. 49 days, last runtime
// Nextion Stuff
String endChar = String(char(0xff)) + String(char(0xff)) + String(char(0xff)); // end-character when sending a message from nextion to arduino.
String dfd = ""; // dfd = data from display
union {
char charByte[4];
long valLong;
} value;
// lofgile stuff
String myLogfile = "";
// --------- TBD --------
// Sensor stuff
// RTC Stuff
// stepper motor stuff
// send text to nextion
void sendValue(const char* adr, const char* msg) {
delay(30);
// construct a command string: "<objectname>.txt="<"message">0xff0xff0xff
String command = String(adr) + ".txt=\"" + String(msg) + "\"";
Serial2.print(command);
Serial2.write(0xff); // write the 3 ending bits to the Nextion
//Serial.println("Command send: " + command);
delay(30);
// Overload function with more parameters for float number
void sendValue(const char* adr, float value, int decimalPlaces) {
delay(30);
// Buffer to hold the formatted float value as a string
char buffer[10];
// Format the float value with the specified number of decimal places
dtostrf(value, 0, decimalPlaces, buffer);
String command = String(adr) + ".txt=\"" + String(buffer) + "\"";
delay(30);
void getNextionData() {
delay(30);
while(Serial2.available()){
dfd += char(Serial2.read()); // adda data do character
// debug print
// Serial.print(dfd);
checkNextionData();
// check the data that was received from Nextion
void checkNextionData(){
// check first characters if they are "val", and check if message length is 11: 3 bytes from text ("val") and 4 bytes per value (f_goal, t_goal)
// Message will be send in format: valxxxxyyyyzzzz
if((dfd.substring(0,3)=="val") & dfd.length()==11) {
getNextionNewValues();
// Start / Stop button
if(dfd =="StartStop") {
getNextionStartStop();
// Get logfile name
if(dfd.startsWith("log") && dfd.endsWith("logEnd")) {
getNextionLogName();
void getNextionNewValues(){
// get force goal value
value.charByte[0] = char(dfd[3]);
value.charByte[1] = char(dfd[4]);
value.charByte[2] = char(dfd[5]);
value.charByte[3] = char(dfd[6]);
f_goal = value.valLong;
// Serial.println("New force goal = " + String(value.valLong));
// debug print
Serial.print(F("New force goal = "));
Serial.println(f_goal);
// get time goal value
value.charByte[0] = char(dfd[7]);
value.charByte[1] = char(dfd[8]);
value.charByte[2] = char(dfd[9]);
value.charByte[3] = char(dfd[10]);
rt_goal = value.valLong;
// debug print
Serial.print(F("New time goal = "));
Serial.println(rt_goal);
dfd = ""; // reset the message string
void getNextionStartStop() {
run = !run; // toggle run flag
digitalWrite(LED_BUILTIN, run ? HIGH : LOW); // toggle the LED
void getNextionLogName() {
myLogfile = dfd.substring(3, dfd.length() - 6); // Position after "log" until position before "logEnd"
// debug print
//Serial.print("Logfile name: ");
//Serial.println(myLogfile);
pinMode(LED_BUILTIN, OUTPUT);
Serial.begin(115200); //open the serial port
Serial2.begin(115200); // open the serial port for Nextion display
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
while (!Serial2) {
Serial.println("==============");
Serial.println("Setup finished");
// debug start parameters
f_LC = 30.0; // debug start value
displ = 5.0; // debug start value
// Collect data from display
if(Serial2.available()) {
getNextionData();
unsigned long rt = millis(); // 0-4'294'967'295 -> ca. 49 days,
if(((rt - rt_last) > rate) && (dfd == "")) {
// read force
// DEBUG ACTIVE ===============
float rand = float(random(-1, 2));
rand = rand / 100.0;
f_LC = f_LC + rand;
// DEBUG FINISHED ===============
// update current force on display
sendValue("f_current", f_LC, 2);
// update current time on display
sendValue("t_current", rt/1000, 1);
// read displ
displ = displ + rand;
// Update plot with displ
// Read RTC
// log data
// if force > or < setpoint, move motor
// Update the lastTime_main to the current time
rt_last = rt;
// debug
//Serial.println("send");
