Nextion library displays with Arduino
Hi
I dont know if this is the right place to ask this question but...
I am using a Nextion display with the original C++ library and try to use it with SdFat standard library (both found in the library manager) and with SoftSerialSpi enabled. I get dual definitions for File and other things that make the code not compile. Is there anyone that has had the same problem and maybe found a solution?
Best regards
Could you take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
