Hi guys, I need some help with my arduino code. I have 2 pages with values. Whenever I change pages, I wan to have the value from before to appear on my display without pressing any button. Eg. in page0 my value in n0.val is 988, when I press a button to change page and go back I want the same value "988" to be in n0.val
I am not sure about my code for the currentpageID
This is my first time using it.
Please help
#include <EasyNextionLibrary.h>
EasyNex myNex(Serial2);
// Debouncing variables
const int incrementButtonPin_1 = 5; // Pin connected to increment button
const int decrementButtonPin_1 = 6; // Pin connected to decrement button
const int incrementButtonPin_2 = 7; // Pin connected to increment button
const int decrementButtonPin_2 = 8; // Pin connected to decrement button
int value1 = 0;
int value2 = 0;
unsigned long pressStartTime = 0;
unsigned long lastUpdateTime = 0;
bool button0Pressed_1 = false;
bool button1Pressed_1= false;
bool button0Pressed_2 = false;
bool button1Pressed_2 = false;
const unsigned long longPressDuration = 1000; // Duration for long press (1 second)
const unsigned long updateInterval = 75; // Interval for updating value1 (75 ms)
void release() {
button1Pressed_1 = false;
pressStartTime = millis();
lastUpdateTime = millis();
myNex.begin(9600);
myNex.writeNum("n0.val", value1); // Initialize number box with value1
myNex.writeNum("n1.val", value2); // Initialize number box with value2
myNex.NextionListen();
checkLongPress();
void trigger0() {
unsigned long currentTime = millis();
button0Pressed_1 = true;
if (currentTime - pressStartTime < longPressDuration) {
value1 += 1; // Short press, decrease value1 by 1
void trigger1() {
release();
void trigger2() {
button1Pressed_1 = true;
value1 = myNex.readNumber("n0.val");
if (value1 > 0) {
value1 -= 1; // Short press, decrease value1 by 1 if value1 is above 0
value1 = 0; // Ensure value1 does not go below 0
} myNex.writeNum("n0.val", value1);
void trigger3() {
release();
void trigger4() {
button0Pressed_2 = true;
value2 += 1; // Short press, decrease value2 by 1
void trigger5() {
release();
void trigger6() {
button1Pressed_2 = true;
value2 = myNex.readNumber("n1.val");
if (value2 > 0) {
value2 -= 1; // Short press, decrease value2 by 1 if value1 is above 0
value2 = 0; // Ensure value1 does not go below 0
} myNex.writeNum("n1.val", value2);
void trigger7() {
release();
void checkLongPress() {
if (button0Pressed_1) {
if (currentTime - pressStartTime > longPressDuration) {
if (currentTime - lastUpdateTime > updateInterval) {
value1 += 1; // Increase value1 by 1 every 75 ms
lastUpdateTime = currentTime;
} else if (button1Pressed_1) {
if (value1 > 0) {
value1 -= 1;} // Decrease value1 by 1 every 75 ms
else if (button0Pressed_2) {
value2 += 1; // Increase value2 by 1 every 75 ms
} else if (button1Pressed_2) {
if (value2 > 0) {
value2 -= 1;} // Decrease value2 by 1 every 75 ms
I don't see any code where you are using the library variables for currentPageID and lastCurrentPageID.
// public variables
/* currentPageId: shows the id of the current page shown on Nextion
* WARNING: At the Preinitialize Event of every page, we must write:
* printh 23 02 50 xx , where xx the id of the page in hex
* (example: for page0, we write: printh 23 02 50 00 , for page9: printh23 02 50 09, for page10: printh 23 02 50 0A)
* Use can call it by writing in the .ino file code: variable = myObject.currentPageId;
* lastCurrentPageId: stores the value of the previous page shown on Nextion
* No need to write anything in Preinitialize Event on Nextion
* You can call it by writing in the .ino file code: variable = myObject.lastCurrentPageId;
command
int currentPageId;
int lastCurrentPageId;
There is a library example code "Change Pages and Send Float Values" which uses the currentPageId and lastCurrentPageId variables.
if I were to set vscope to global only will do right?
And quick question, i am using nextion NX8048K050_011. I have another HMI file. When I upload that file into the nextion, there is an error, saying insufficient space. what can I do to solve it?
I will post in another topic. Please do check it out and see if I could improve in any way
Your two or more topics on the same or similar subject have been merged.
Please do not duplicate your questions as doing so wastes the time and effort of the volunteers trying to help you as they are then answering the same thing in different places.
Please create one topic only for your question and choose the forum category carefully. If you have multiple questions about the same project then please ask your questions in the one topic as the answers to one question provide useful context for the others, and also you won’t have to keep explaining your project repeatedly.
Repeated duplicate posting could result in a temporary or permanent ban from the forum.
Could you take a few moments to Learn How To Use The Forum
I got it alrdy.
Its because in my textbox I tend to set the maxl of the textbox to a very long length
After setting in a proper way, i got it right. Thank you.
Now I have another problem. Earlier, in the nextion editor, I set the display to the basic display. And it worked. now when I set it to the enhanced version, it does not worked. When Reset it back to basic version also didn't work.. Could be because of virus as u said?
(I have mentioned this similar problem in another topic before. It seems it occurred again)
Its like this:
Earlier i set the model to the basic model and connect it to the basic model and upload it.
The display is shown and the arduino run as it should.
When I set the model to the enhanced model, connect to the enhanced model and upload it, the display is shown. But its not working according the code. Nothing in the nextion display is functioning.
I also have no idea abt the virus. Is there any way I can do, to have you see the code without the virus.
This is my first time having this kind of situation. I don't have any other nextion model.
I guess you can not switch models like that. Different models have different features and capabilities, and it would seem that code needs to be written or copied into the editor and compiled when it is set for the model.
I done that before.
I opened a new file for nextion editor and do it step by step.
Same problem.
The shocking part is tht after testing the enhanced version, going back to the basic model. the basic is not working. The arduino is copy and paste. i even try using a different arduino board. initially i was using arduino mega (Serial2) changing to arduino nano every (Serial). Even after changing, same problem
My recommendation would be to uninstall the Nextion Editor and start with a clean version. Do not open any existing files with the new editor, but recode them. I would hope the behaviour of the Nextion is better.
None of what you are experiencing has ever happened to me, but I only have one Nextion model.
