Nextion Touch Screen
Must drink less
:confused:
Hello Ian,
Firstly, I want to say that you made an excellant work designing the .HMI file for Nextion.
I wrote a code for the Arduino, that works without the need of a Nextion library. I tried to make it as simple as I could and as close to begginer-friendly as possible.
The project is now met with the terms of the open-source GNU General Public License, as all open-source projects should do.
I mention your name as well, for the .HMI design.
Some information about the project:
You can control any relay, by pressing any button on the screen. The buttons were changed from dual-state to push buttons, in order to change the background picture < .picc > from Arduino, only when the state of the relay is changed, so as to have a real feedback of the actual relay condition-state.
Also, a function was added to detect if Nextion is alive, by turning on a LED on pin 12. You could put a buzzer if you like to. In order to do that, a timer component was added on Nextion that sends an ‚Äúalive message‚ÄĚ to Arduino every 4,9 seconds in combination with a timer on Arduino, that has been set to 10 seconds, and if the ‚Äúalive message‚ÄĚ isn‚Äôt received in 10 seconds or less, the pin 12 goes HIGH.
In addition, the page on Nextion refreshes every minute with the real state of the relays.
Much more, at the comments inside the code.
//              ______________________________________________
               //--------CREATED BY SEITANIS THANASIS--------\\
              //---------------VERSION 28/10/2019-------------\\
             //----------------- www.seithan.com --------------\\
            //----------------seithagta@gmail.com---------------\\
           //---code for Power relays controlled with Nextion----\\
          //----The design on Nextion's page is from Ian Suggy----\\
/*  Code for controlling Power Relays with Nextion and Arduino or other MCUs
 *  Copyright (C) 2019 author: THANASIS SEITANIS contact: seithagta@gmail.com
 *  This program is free software: you can redistribute it and/or modify
 *  it under the terms of the GNU General Public License as published by
 *  the Free Software Foundation, either version 3 of the License, or
 *  any later version.
 *  This program is distributed in the hope that it will be useful,
 *  but WITHOUT ANY WARRANTY; without even the implied warranty of
 *  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
 *  GNU General Public License for more details.
 *  You should have received a copy of the GNU General Public License
 *  along with this program.  If not, see <https://www.gnu.org/licenses/>.
 *  Not legally state for the distribution terms:
 *  It is permitted to copy and distribute native copies of the Program source code
 *  exactly as you have obtained it, on any storage medium, provided that:
 *  you will prominently and appropriately publish, in each copy, a copyright notice
 *  and a disclaimer of guarantee - that you will integrally include all notes mentioned
 *  in this License and in the absence of any warranty - and, finally, that you will provide
 *  each other recipient of the Program with a copy of this License together with the Program.
 *  You should make sure that the modified files provide prominent notes
 *  indicating the modification of the files and the date of modification.
//------END OF COPYRIGHT NOTICE AND DISCLAIMER OF GUARANTEE------\\
 * ő§he pins that every relay is connected to
 * 2 Enclosure_Controller 2
 * 3 Enclosure_Heater 3
 * 4 Amp_Meters 4
 * 5 Electronics_Lights 5
 * 6 PSU_Fans 6
 * 7 Control_Board_Fans 7
 * 8 Motor_Fans 8
 * 9 HotEnd_Lights 9
 * 12 pin output that comes HIGH when synq with Nextion lost can use it for led, buzzer etc
/* define that Serial will de writed as "Nextion" (when we write Nextion.print the compiler reads Serial.print)
 *By defining the Nextion as Serial you can change at once the serial port at the whole code,
 * by changing the Serial to Serial1 for example
#define Nextion Serial
#define REFRESH_TIME 60000 // time to refresh the Nextion page every 3 minutes
#define TIMEOUT_FOR_SYNQ 10000
  /* if this time is exceeded,
   * and Nextion doesn't send a confirmation message that it is alive,
   * the system will fall in safe mode and turn the relays off.
boolean relay_state [8];  //An array with 8 places to store the Relays stage in booleans TRUE or FALSE
                          // LOW = false (relay off)    HIGH = true (relay on)
unsigned long timeout_synq = millis();
unsigned long refresh_timer = millis();  // timer for refreshing Nextion's page
void setup(){
  Nextion.begin(9600); // starting the serial port at 9600. NEXTION MUST HAVE THE SAME RATE. For this we write at
                       //  first page to the preinitialize event the command < baud=9600 >
                       // NOTE "bauds" will change the default baud rate off 9600 until it changed again
  for(int i = 0; i < 8; i++){
    relay_state[i] = false; //Setting the values of array relay_state to false (LOW)
    pinMode(i+2, OUTPUT); // Setting all pins as OUTPUT
    digitalWrite(i+2, LOW); //Setting all the relays to LOW (off)
    pinMode(12,OUTPUT);
    digitalWrite(12,LOW);
  delay(500); //Waiting for Nextion to initialize
  /*reading the relay_state array and refreshing the Nextion page by sending the actual condition of the relays,
  * by sending < b(i).picc=0 > (the red picture) for those that are off (LOW) (false)
  * or by sending < b(i).picc=1 > (the green picture) for those that are on (HIGH) (true)
  * so as to have a feedback of the actual condition - state of the relays
  * because changing the color from Nextion, we do not ensure that the command has been excecuted from Arduino,
  * and we would see a fake green colored button (relay is on), without the relay being ON in real
    if(relay_state[i] == false){
      Nextion.print("b");
      Nextion.print(i);
      Nextion.print(".picc=0");
    }else if(relay_state[i] == true){
      Nextion.print("b");
      Nextion.print(i);
      Nextion.print(".picc=1");
    TFT_EndCommand(); // Sending the three bytes in order to terminate the instructions as Nextion needs < Nextion.print("\xFF\xFF\xFF"); >
void loop(){
  if((millis()-refresh_timer) > REFRESH_TIME){
    Relay_control();
  Nextion_serial_listen();
  check_Nextion_synq();
The other part of the code, is on the next post.
-Thanasis Seitanis
Nextion_relay_contol_v02.ino (11.2 KB)
Nextion_relay_contol_v02.zip (450 KB)
void Nextion_serial_listen()
We are going to use the following Data Format:
<#> <len> <cmd> <Relay_button_number>
*        <#> declares that a command is followed
*        <len> declares the number of bytes that will follow (len = 2, <cmd> is the one Byte < Relay_button_number > is the other)
*        <cmd> declares the group of commands (R = Relay Control),you can add a different command group  later.
*        < Relay_button_number > is the Number of the button on Nextion (b0, b1...b7) that controls the relay
* From Nextion, at the release even of the button, we write: < printh 23 02 52 00 >, for b0
* For b1: < printh 23 02 52 01 > and so on...
    if(Nextion.available() > 2){                 // Read if more then 2 bytes come (we always send more than 2 <#> <len> <cmd> <id>
        char start_char = Nextion.read();      // Create a local variable (start_char) read and store the first byte on it
        if(start_char == '#'){                // And when we find the character #
          uint8_t len = Nextion.read();      // Create local variable (len) / read and store the value of the second byte
                                            // <len> is the lenght (number of bytes following)
          uint8_t Relay_button_number;     // create variable to store the button number
          unsigned long tmr_1 = millis();
          boolean cmd_found = true;
          while(Nextion.available() < len){ // Waiting for all the bytes that we declare with <len> to arrive
            if((millis() - tmr_1) > 100){    // Waiting... But not forever......
              cmd_found = false;              // tmr_1 a timer to avoid the stack in the while loop if there is not any bytes on Serial
            delay(1);                           // Delay for nothing delete it if you want
            if(cmd_found == true){            // So..., A command is found (bytes in Serial buffer egual more than len)
              uint8_t cmd = Nextion.read();  // Create local variable (cmd). Read and store the next byte. This is the command group
              switch (cmd){
               case 'R':
                        /* or <case 0x52:>  IF 'R' matches, we have the command group "Relay control".
                        * The next byte  according to our protocol is the value for the <Relay_button_number>
                  Relay_button_number = Nextion.read();  // we read and store the byte at the variable
                  if(relay_state[Relay_button_number] == false){
                    relay_state[Relay_button_number] = true;
                  }else if(relay_state[Relay_button_number] == true){
                    relay_state[Relay_button_number] = false;
                  timeout_synq = millis(); // setting the timer to be equal to millis(), because Nextion sent a alive message
                  Relay_control();
                    case 'S':
                   /* or <case 0x53:>  if 'S' matches, we have the command group "Nextion is Synchronized".
                    * From the timer component on Nextion, we send every 4,9 seconds a < printh > command
                    * so we check if Nextion is connected and synchronized.
                    * If it is not, pin 12 turns HIGH as Alarm
                    * We check the above, by writing in the timer's event: < printh 23 01 53 >
void Relay_control()
  * and we would see a fake green colored button (relay is on), without the relay being ON in real.
  * We also added the digitalWrite , in order to turn OFF or ON the relays.
  * The button b0 is stored at 0 place of array relay_state[0] , but the pins start from 2.
  * That is why we add +2 at digitalWrite command.
      Nextion.print("b");
      Nextion.print(i);
      digitalWrite(i+2, HIGH);
      Nextion.print("b");
      Nextion.print(i);
    delay(1); //just to give Nextion some time to read the Serial (it is not necessary)
void check_Nextion_synq()
 if((millis() - timeout_synq) > TIMEOUT_FOR_SYNQ ) {
     digitalWrite(12,HIGH);
     /* you could put a buzzer here (pin 12) to notify you that the connection is lost
      * for the LED, you will need a 220ohm in series.
      * Here we turn the buzzer or the LED on
    }else{
    digitalWrite(12,LOW); //stops the LED or the buzzer if synq comes back
void TFT_EndCommand()
Hi Seithan
1st
Thanks for all your hard work and taking the time to do this for me and explaining what each command does. It helps me understand whats going on and no doubt it will help others.
When it says ‚ÄúdigitalWrite(i+2, LOW); //Setting all the relays to LOW (off)‚ÄĚ the relays turn on, I know I can wire the relays ether nc or no and the relays would still work but I would rather the relays be off as there are some that would be off more than on, hope you understand what I mean?
I have changed the following lines
72: relay_state = true; //Setting the values of array relay_state to false (LOW) false to true
74: digitalWrite(i+2, HIGH); //Setting all the relays to LOW (off) LOW to HIGH
91: if(relay_state == true){ false to true
95: }else if(relay_state == false){ true to false
200: if(relay_state == true){ false to true
201: digitalWrite(i+2, HIGH); low to high
205 }else if(relay_state == false){ true to false
206 digitalWrite(i+2, LOW); high to low
Everything seems to work ok, is there anything else I should change or if I shouldn’t do so why is it best not to change anything?
As I understand, the relays are normaly closed. So with pin at HIGH, interior lighting for example, is going to be off.
Is that right?
Yes that is right. The relays or both normally closed and normally open
Like this one
8 Way Relay
Hi Ian,
I am impressed that you read and understood the code that quick for a begginer and made corrections by targeting at the appropriate points of code.
I checked the changes you made, and everything is fine. Nothing else is needed. You are doing so well. Keep this up.
-Thanasis Seitanis
PerryBebbington:
First off, understand that I do not know anything much about the Nextion libraries...
If you have no experience with nextion displays you should not confuse people. Maybe you should look at what the other contributor had to write (more positive and solved the issue) and maybe do the same...
Sorry to resurrect an old topic, but I had the same issue and google directed me here, only for me to get upset by your post, its these attitudes that make me stay clear from this website. Its like a given here if you ask a question you will get a lecture on how to behave etc etc, and from people that don't have a clue themselves about the topic. Luckily I know a little whats going on so when reading your reply I just skipped to next answer.
The main issue with the errors is that the Nextion library by default is set up for an Arduino Mega which has several serial ports, including Serial2... I know this is an old topic but still actual.
The NextConfig.h file needs to be updated...there is a note at the git page for nextion library that mentions this. If you are using nano or uno...
GitHub - itead/ITEADLIB_Arduino_Nextion :
"...Note: the default configuration is for MEGA2560."
NextConfig.h (file in arduino libararies)
Line 27 change to //#define DEBUG_SERIAL_ENABLE
Line 32 #define dbSerial Serialxxx
Line 37 #define nexSerial Serial
And problem solved. Everything compiles and works.
For those that want to try Nextion library example with nano and Uno, etc
mixamode:
If you [Perry Bebbington] have no experience with nextion displays you should not confuse people.
He didn't say he had no experience with the displays, but with the libraries.
I think I've seen other posts from Perry Bebbington where he rolled his own Nextion code.
I have seen the lengthy instructions on his library too, kudos to him. But why when you can solve the issue with two lines? The issue is that, that poor fellow would have to rewrite his whole sketch, plus download and install a different library, how confusing can that be for a beginner?
I think the other contributor felt sorry for him and wrote the whole sketch for him plus the hmi file, what a great thing to do.
mixamode:
If you have no experience with Nextion displays you should not confuse people.
Where have I said I have no experience with Nextion displays?
evande:
Thank you evande, that is correct.
Yes, I have a tutorial on here using my own code.At the moment there are 2 approaches to Nextion supported on here, mine without a library and Seithan's with his methods. Both work, some people prefer one, some the other. AFAIK no one here is providing support for the official Nextion libraries.
PerryBebbington:
.... for some definition of "official" :wink:
evadne:
To be clear to anyone reading this I mean the libraries provided by Itead for their Nextion displays.
For the benefit of anyone reading this, at the time of typing no one who regularly contributes to these fora provides support for the Itead Nextion libraries. Maybe that will change and I encourage anyone who has a good understanding of them to start answering questions about them.
Most of the support either comes from me about my methods as outlined in the tutorial 'using Nextion displays with Arduino' or from Seithan about his methods. Both methods work but they are different, you have to go with whichever you are comfortable with.
