I'm using the Nextion and arduino display to control the speed (RPM) of a stepper motor.
Everything works.
But I need feedback from the arduino for the nextion of the amount of RPM (revolutions) and
I am not using nextion library. (include nextion.h only for command nextInit() )
How to send data from arduino to Nextion without the print command, is there another way?
tks
Why would you need to? Serial.print() does everything you need. I know from your other question that you know how to use it.
I had a problem with my project.
(that little video I showed you)
A print command was being run continuously and
was braking the stepper motor.
I solved it with a variable causing the print to be executed only once.
Thanks again and I'm sorry.
