NFC and TINY RTC
I need some assistance with a running a RTC and a NFC sheild
NFC
http://www.elechouse.com/elechouse/index.php?main_page=product_info&cPath=90_93&products_id=2205
RTC
I can use the with out a problem independently but as they both use SCL and SDA any ideas how to fix it
It looks like the RTC has two SDA and SCL connections.
Can you go Arduino SDA/SCL > RTC1-SDA/SCL > RTC2-SDA/SCL > NFC?
yer i though i may be a pass through but for some reason it did not seem to work i may have been a user issue i will check it out and let you know.
thanks
Nath
I frequently have user issues.
tried that with no luck, the NFC does not connect if the RTC is in front of it
I'm reading this:
"I2C allows you to have multiple devices connected to the same two lines (collectively called a bus)"
which is suggesting to me you can have both the RTC and the NFC connected to 4 and 5 on an Uno and the controller will sort it out.
Look here:
http://www.robot-electronics.co.uk/acatalog/I2C_Tutorial.html
TIL.
i think you are correct it looks like i must have had a wiring issue..
no just need to sort out why my rtc does not want to keep the time.
Thanks for all your help :slight_smile:
