NFC Disengagement
I have NFC module and tag in a system, I am trying to disconnect it without disconnecting the Modules from the PCB, any advice or suggestion for it.
Thanks in advance
are you saying that you want it to be removed from being supplied power or do you want to just to have your arduino think its no longer there?
pictures or full description would help us help you.
Usually the easier way to power down a peripheral is this:
  1. Set all the OUTPUT pins connected to it to INPUT
  2. switch its Vcc off using a PNP or pFET and another pin dedicated to controlling the power.
Reversing the procedure is the exact reverse.
Using a PNP or pFET switch means you can keep grounds common, which often finesses some
problems. Google 'high side switching'.
Its vital not to phantom-power the peripheral so those logic outputs connected to it must be
disabled whenever the thing is powered down. Google 'phantom power' and 'CMOS latchup'.
But if a module has an enable or shutdown pin anyway, that is the thing to use.
