I am trying to use the upload basic code example for NFC chip using Arduino UNO.
I am using Arduino v1.8.5. Which library to be included to make it work.
2)where i can get library associated with it.
- where to paste in library.
Like in older version v1.0.1 if i download any library i could able to paste in
E:\arduino-1.0.1\libraries path like this . when i restart libaray will be included. But if i do same thing PN532 library will not be added in v 1.8.5
With current version
/* PN532 NFC RFID module V3 (PN532) [S192] : http://rdiot.tistory.com/173 [RDIoT Demo] */
#include <Wire.h>
#include <PN532_I2C.h>
#include <PN532.h>
#include <NfcAdapter.h>
PN532_I2C pn532i2c(Wire);
PN532 nfc(pn532i2c);
void setup(void) {
Serial.println("Hello!");
nfc.begin();
uint32_t versiondata = nfc.getFirmwareVersion();
if (! versiondata) {
Serial.print("Didn't find PN53x board");
while (1); // halt
// Got ok data, print it out!
Serial.print("Found chip PN5"); Serial.println((versiondata>>24) & 0xFF, HEX);
Serial.print("Firmware ver. "); Serial.print((versiondata>>16) & 0xFF, DEC);
Serial.print('.'); Serial.println((versiondata>>8) & 0xFF, DEC);
// Set the max number of retry attempts to read from a card
// This prevents us from waiting forever for a card, which is
// the default behaviour of the PN532.
nfc.setPassiveActivationRetries(0xFF);
// configure board to read RFID tags
nfc.SAMConfig();
Serial.println("Waiting for an ISO14443A card");
void loop(void) {
boolean success;
uint8_t uid[] = { 0, 0, 0, 0, 0, 0, 0 }; // Buffer to store the returned UID
uint8_t uidLength; // Length of the UID (4 or 7 bytes depending on ISO14443A card type)
// Wait for an ISO14443A type cards (Mifare, etc.). When one is found
// 'uid' will be populated with the UID, and uidLength will indicate
// if the uid is 4 bytes (Mifare Classic) or 7 bytes (Mifare Ultralight)
success = nfc.readPassiveTargetID(PN532_MIFARE_ISO14443A, &uid[0], &uidLength);
if (success) {
Serial.println("Found a card!");
Serial.print("UID Length: ");Serial.print(uidLength, DEC);Serial.println(" bytes");
Serial.print("UID Value: ");
String hex_value = "";
for (uint8_t i=0; i < uidLength; i++)
Serial.print(" 0x");Serial.print(uid[i], HEX);
//Serial.print(" ");Serial.print(uid[i], HEX);
hex_value += (String)uid[i];
Serial.println(", value="+hex_value);
if(hex_value == "16517722582") {
Serial.println("This is Key Tag. ");
else if(hex_value == "230522426") {
Serial.println("This is Card Tag. ");
else if(hex_value == "63156295") {
Serial.println("This is Phone Tag. ");
Serial.println("I don't know.");
Serial.println("");
// Wait 1 second before continuing
// PN532 probably timed out waiting for a card
Serial.println("Waiting for a card...");
E:\Projects\NFC communication\Test_Method\basic_test\basic_test.ino:4:23: fatal error: PN532_I2C.h: No such file or directory
compilation terminated.
Multiple libraries were found for “Wire.h”
Used: C:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire
Not used: C:\Program Files\Arduino\libraries\Wire
exit status 1
Error compiling for board Arduino/Genuino Uno.
