NFC library
Hello,
I'm searching a NFC library but I couldn't find one. Here Libraries - Arduino Reference there are a lot but I didn't find NFC or RDIF library. Could you help me?
Thanks!
to which device should it talk?
often libraries are named after the sensor, not necessary the protocol...
I don't know. I want to make a NFC access control. What's the difference between a NFC shield and a NFC module?
Maybe this:
NFC Shield
NFC Module
Thanks!
hi most of the NFC hardware uses a PN532 Library you will find that most of them use the same chip set so you should be able to use the Adafruit one
