Sera a tutti, vi scrivo alle 5 di mattina perchè è tutta la notte che sbatto la testa cercando di far funzionare questo modulo per arduino:
http://www.dfrobot.com/wiki/index.php/NFC_Module_for_Arduino_(SKU:DFR0231)
Il funzionamento sembra semplice, il codice che uso è molto simile a quello dell'esempio nella pagina citata, ho apportato un paio di attamenti per farlo funzionare su un arduino uno, ovvero, al posto di Serial1 uso una connessione seriale creata con la libreria SoftwareSerial.
Riporto qui il codice.
PN532 reads the tag by Arduino mega/Leonardo
command list:
#wake up reader
send: 55 55 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ff 03 fd d4 14 01 17 00
return: 00 00 FF 00 FF 00 00 00 FF 02 FE D5 15 16 00
#get firmware
send: 00 00 FF 02 FE D4 02 2A 00
return: 00 00 FF 00 FF 00 00 00 FF 06 FA D5 03 32 01 06 07 E8 00
#read the tag
send: 00 00 FF 04 FC D4 4A 01 00 E1 00
return: 00 00 FF 00 FF 00 00 00 FF 0C F4 D5 4B 01 01 00 04 08 04 XX XX XX XX 5A 00
XX is tag.
//************* start **************
const unsigned char wake[24]={
0x55, 0x55, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, \
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xff, 0x03, 0xfd, 0xd4, 0x14, 0x01, 0x17, 0x00};//wake up NFC module
const unsigned char firmware[9]={
0x00, 0x00, 0xFF, 0x02, 0xFE, 0xD4, 0x02, 0x2A, 0x00};//
const unsigned char tag[11]={
0x00, 0x00, 0xFF, 0x04, 0xFC, 0xD4, 0x4A, 0x01, 0x00, 0xE1, 0x00};//detecting tag command
const unsigned char std_ACK[25] = {
0x00, 0x00, 0xFF, 0x00, 0xFF, 0x00, 0x00, 0x00, 0xFF, 0x0C, \
0xF4, 0xD5, 0x4B, 0x01, 0x01, 0x00, 0x04, 0x08, 0x04, 0x00, 0x00, 0x00, 0x00, 0x4b, 0x00};
unsigned char old_id[5];
unsigned char receive_ACK[25];//Command receiving buffer
//int inByte = 0; //incoming serial byte buffer
#include "SoftwareSerial.h"
SoftwareSerial NFC_Module(10,11);
#if defined(ARDUINO) && ARDUINO >= 100
#include "Arduino.h"
#define print1Byte(args) NFC_Module.write(args)
#define print1lnByte(args) NFC_Module.write(args),NFC_Module.println()
#else
#include "WProgram.h"
#define print1Byte(args) NFC_Module.print(args,BYTE)
#define print1lnByte(args) NFC_Module.println(args,BYTE)
#endif
Serial.begin(9600); // open serial with PC
NFC_Module.begin(115200); //open serial1 with device
//Serial2.begin(115200);
wake_card();
delay(100);
read_ACK(15);
delay(100);
display(15);
send_tag();
read_ACK(25);
delay(100);
if (!cmp_id ()) {
if (test_ACK ()) {
display (25);
delay (100);
copy_id ();
void copy_id (void)
{//save old id
int ai, oi;
for (oi=0, ai=19; oi<5; oi++,ai++) {
old_id[oi] = receive_ACK[ai];
char cmp_id (void)
{//return true if find id is old
int ai, oi;
for (oi=0,ai=19; oi<5; oi++,ai++) {
if (old_id[oi] != receive_ACK[ai])
return 0;
return 1;
int test_ACK (void)
{// return true if receive_ACK accord with std_ACK
int i;
for (i=0; i<19; i++) {
if (receive_ACK[i] != std_ACK[i])
return 0;
return 1;
void send_id (void)
{//send id to PC
int i;
Serial.print ("ID: ");
for (i=19; i<= 23; i++) {
Serial.print (receive_ACK[i], HEX);
Serial.print (" ");
Serial.println ();
void UART1_Send_Byte(unsigned char command_data)
{//send byte to device
print1Byte(command_data);
NFC_Module.flush();// complete the transmission of outgoing serial data
#endif
void UART_Send_Byte(unsigned char command_data)
{//send byte to PC
Serial.print(command_data,HEX);
Serial.print(" ");
void read_ACK(unsigned char temp)
{//read ACK into reveive_ACK[]
unsigned char i;
for(i=0;i<temp;i++) {
receive_ACK[i]= NFC_Module.read();
void wake_card(void)
{//send wake[] to device
unsigned char i;
for(i=0;i<24;i++) //send command
UART1_Send_Byte(wake[i]);
void firmware_version(void)
{//send fireware[] to device
unsigned char i;
for(i=0;i<9;i++) //send command
UART1_Send_Byte(firmware[i]);
void send_tag(void)
{//send tag[] to device
unsigned char i;
for(i=0;i<11;i++) //send command
UART1_Send_Byte(tag[i]);
void display(unsigned char tem)
{//send receive_ACK[] to PC
unsigned char i;
for(i=0;i<tem;i++) //send command
UART_Send_Byte(receive_ACK[i]);
Il problema si presenta immediatamente, il comando di "wake up" non funziona, o almeno così credo, dato che mi da una risposta diversa da quella riportata dalla documentazione e successivamente non rileva nessuna card.
La risposta che esce è:
0 80 0 0 0 80 2 FF 75 25 9 F8 FF FF FF
quando dovrebbe essere:
Ho provato anche gli altri comandi, ovvero il "get firmware" e il "read the tag" che rispettivamente mi restituiscono:
0 80 0 0 0 80 6 FD 75 20 53 90 E8 8 7 FC FF FF FF
e
0 80 0 0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Non sono un esperto di sistemi rfid, quindi può essermi sfuggito qualcosa di basilare, purtroppo ho fatto l'errore di affidarmi a un modulo quasi privo di documentazione.
Per escludere le cose ovvie ho provato diversi pin per la connessione, sia l'alimentazione a 3.3v sia quella a 5v e anche diversi baud rate per la connessione seriale al pc.
Sono grato a chiunque possa darmi qualche consiglio.
