NFC Module slowing down program
I have the problem, that my NFC Module V3 by ELECHOUSE slows down the program after about one minute of the program running.
I have already tried lots of stuff and can't seem to find a solution.
Any help is appreciated :slight_smile:
Heres the code regarding the NFC stuff.
#include <Adafruit_PN532.h>
// define values for the NFC reader
uint16_t timeout = 100;
uint8_t knownUID[] = {0x04, 0x1E, 0x6D, 0x89, 0x78, 0x00, 0x00};
uint8_t knownUIDLength = sizeof(knownUID) / sizeof(knownUID[0]);
unsigned int lastNFCCheck = 0;
unsigned int nfcInterval = 1000; // Check NFC every 1000ms
Adafruit_PN532 nfc(2, 3, &Wire);
void readNFC() {
    // only check in certain intervals
    if (millis() - lastNFCCheck >= nfcInterval) {
        lastNFCCheck = millis();
        uint8_t uid[7];
        uint8_t uidLength;
        // read NFC
        if (nfc.readPassiveTargetID(PN532_MIFARE_ISO14443A, uid, &uidLength, timeout)) {
            Serial.print("UID: ");
            for (uint8_t i = 0; i < uidLength; i++) {
                if (uid[i] < 0x10) Serial.print("0");
                Serial.print(uid[i], HEX);
                if (i < uidLength - 1) Serial.print(":");
            // compare with known UID and authenticate user
            authenticateUser(uidLength == knownUIDLength && compareUIDs(uid, knownUID, uidLength));
nfc.begin();
    if (nfc.getFirmwareVersion()) {
        nfc.SAMConfig();
        Serial.println("NFC Ready");
void loop(){
    readNFC();
The program you posted doesn't run at any speed, it won't compile.
Are you using SPI or I2C? Do you have a genuine Adafruit PN532 ?
more info @ Arduino Library | Adafruit PN532 RFID/NFC Breakout and Shield | Adafruit Learning System
