I have a project much like the many door locking projects around the web…however I want to create a database on SD card and have the arduino read and compare the number with that database. and edit that number with a character that disables the number form the database without deleting it.
The following project would fit my needs however I would have to enter the number in the sketch instead of the SD. therefore making a limitation to the number of entries.
I found the Babel Fish project from Adafruit to be a close parallel to my project. here is that code as given by that programmer:
#include <WaveHC.h>
#include <WaveUtil.h>
#include <Wire.h>
#include <Adafruit_NFCShield_I2C.h>
#define IRQ 6 // this trace must be cut and rewired!
#define RESET 8
Adafruit_NFCShield_I2C nfc(IRQ, RESET);
SdReader card; // This object holds the information for the card
FatVolume vol; // This holds the information for the partition on the card
FatReader root; // This holds the information for the volumes root directory
FatReader file; // This object represent the WAV file for a pi digit or period
WaveHC wave; // This is the only wave (audio) object, since we will only play one at a time
- Define macro to put error messages in flash memory
#define error(msg) error_P(PSTR(msg))
//////////////////////////////////// SETUP
// set up Serial library at 9600 bps
PgmPrintln(“Pi speaker”);
if (!card.init()) {
error(“Card init. failed!”);
if (!vol.init(card)) {
error(“No partition!”);
if (!root.openRoot(vol)) {
error(“Couldn’t open dir”);
PgmPrintln(“Files found:”);
root.ls();
// find Adafruit RFID/NFC shield
nfc.begin();
uint32_t versiondata = nfc.getFirmwareVersion();
if (! versiondata) {
Serial.print(“Didn’t find PN53x board”);
while (1); // halt
// Got ok data, print it out!
Serial.print(“Found chip PN5”); Serial.println((versiondata>>24) & 0xFF, HEX);
Serial.print("Firmware ver. "); Serial.print((versiondata>>16) & 0xFF, DEC);
Serial.print(’.’); Serial.println((versiondata>>8) & 0xFF, DEC);
// configure board to read RFID tags
nfc.SAMConfig();
/////////////////////////////////// LOOP
unsigned digit = 0;
uint8_t success;
uint8_t uid = { 0, 0, 0, 0, 0, 0, 0 }; // Buffer to store the returned UID
uint8_t uidLength; // Length of the UID (4 or 7 bytes depending on ISO14443A card type)
// wait for RFID card to show up!
Serial.println(“Waiting for an ISO14443A Card …”);
// Wait for an ISO14443A type cards (Mifare, etc.). When one is found
// ‘uid’ will be populated with the UID, and uidLength will indicate
// if the uid is 4 bytes (Mifare Classic) or 7 bytes (Mifare Ultralight)
success = nfc.readPassiveTargetID(PN532_MIFARE_ISO14443A, uid, &uidLength);
uint32_t cardidentifier = 0;
if (success) {
// Found a card!
Serial.print(“Card detected #”);
// turn the four byte UID of a mifare classic into a single variable #
cardidentifier = uid[3];
cardidentifier <<= 8; cardidentifier |= uid[2];
cardidentifier <<= 8; cardidentifier |= uid[1];
cardidentifier <<= 8; cardidentifier |= uid[0];
Serial.println(cardidentifier);
// repeat this for loop as many times as you have RFID cards
if (cardidentifier == 2588581390) { // this is the card’s unique identifier
playcomplete(“1.WAV”); // these are file names for the sample audio files - change them to your own file names
if (cardidentifier == 2146122274) {
playcomplete(“2.WAV”);
/////////////////////////////////// HELPERS
- print error message and halt
void error_P(const char str) {
PgmPrint("Error: ");
SerialPrint_P(str);
sdErrorCheck();
while(1);
/ - print error message and halt if SD I/O error
void sdErrorCheck(void) {
if (!card.errorCode()) return;
PgmPrint("\r\nSD I/O error: “);
Serial.print(card.errorCode(), HEX);
PgmPrint(”, ");
Serial.println(card.errorData(), HEX);
while(1);
/ - Play a file and wait for it to complete
void playcomplete(char *name) {
playfile(name);
while (wave.isplaying);
// see if an error occurred while playing
sdErrorCheck();
- Open and start playing a WAV file
void playfile(char *name) {
if (wave.isplaying) {// already playing something, so stop it!
wave.stop(); // stop it
if (!file.open(root, name)) {
PgmPrint("Couldn’t open file ");
Serial.print(name);
return;
if (!wave.create(file)) {
PgmPrintln(“Not a valid WAV”);
return;
// ok time to play!
wave.play();
Any help with an existing sketch similar to this that would allow this to happen would be appreciated or advice on how to accomplish this using edits.
