NFC Shield Seeedstudio v2.0 error
hello i am using seedstudio nfc shield v2 with roboduino with atmega 328 ( based on Arduino Diecimila) when uploading example of readallmifare tags given by seeedstudio it throws an error of "Hello! Didn't find PN53x board " in serial monitor..
i just connected seeedstudio with roboduino, did i miss some connection?
what is probability of my board not working?
Probably yes, but how can we tell? There is no wring diagram or photo of how you done it.
Provide links to the hardware you're using and post the code you use for testing.
i’ll post the photos of wiring diagram and code in 2-3 hrs!
Here are the images! so i just have to connect shield on the top of roboduino, anything else??
and when i use this sketch i m getting error of Didn’t find PN53x Board!
//This example reads all MIFARE memory block from 0x00 to 0x63.
//It is tested with a new MIFARE 1K cards. Uses default keys for authenication.
//Contributed by Seeed Technology Inc (www.seeedstudio.com)
#include <PN532.h>
#include <SPI.h>
/*Chip select pin can be connected to D10 or D9 which is hareware optional*/
/*if you the version of NFC Shield from SeeedStudio is v2.0.*/
#define PN532_CS 10
PN532 nfc(PN532_CS);
#define  NFC_DEMO_DEBUG 1
void setup(void) {
#ifdef NFC_DEMO_DEBUG
  Serial.println("Hello!");
#endif
  nfc.begin();
  uint32_t versiondata = nfc.getFirmwareVersion();
  if (! versiondata) {
    Serial.print("Didn't find PN53x board");
#endif
    while (1); // halt
  // Got ok data, print it out!
  Serial.print("Found chip PN5");
  Serial.println((versiondata>>24) & 0xFF, HEX);
  Serial.print("Firmware ver. ");
  Serial.print((versiondata>>16) & 0xFF, DEC);
  Serial.print('.');
  Serial.println((versiondata>>8) & 0xFF, DEC);
  Serial.print("Supports ");
  Serial.println(versiondata & 0xFF, HEX);
#endif
  // configure board to read RFID tags and cards
  nfc.SAMConfig();
void loop(void) {
  uint32_t id;
  // look for MiFare type cards
  id = nfc.readPassiveTargetID(PN532_MIFARE_ISO14443A);
  if (id != 0)
    Serial.print("Read card #");
    Serial.println(id);
#endif
    uint8_t keys[]= { 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF };// default key of a fresh card
    for(uint8_t blockn=0;blockn<64;blockn++)
      if(nfc.authenticateBlock(1, id ,blockn,KEY_A,keys)) //authenticate block blockn
        //if authentication successful
        uint8_t block[16];
        //read memory block blockn
        if(nfc.readMemoryBlock(1,blockn,block))
          //if read operation is successful
          for(uint8_t i=0;i<16;i++)
            //print memory block
            Serial.print(block[i],HEX);
            if(block[i] <= 0xF) //Data arrangement / beautify
              Serial.print("  ");
              Serial.print(" ");
          Serial.print("| Block ");
          if(blockn <= 9) //Data arrangement / beautify
            Serial.print(" ");
          Serial.print(blockn,DEC);
          Serial.print(" | ");
          if(blockn == 0)
            Serial.println("Manufacturer Block");
            if(((blockn + 1) % 4) == 0)
              Serial.println("Sector Trailer");
              Serial.println("Data Block");
#endif
  delay(2000);
Please help ! what am i doing wrong!!
i am newbie in using this nfc!
and when i flashed this code, instead of Didn’t find PN53x Board error some random Garbage value came on serial monitor which changed everytime i connected shield! a two digit garbage value like latin alphabets (Ä)
    @file     readMifare.pde
    @author   Adafruit Industries
    @license  BSD (see license.txt)
    This example will wait for any ISO14443A card or tag, and
    depending on the size of the UID will attempt to read from it.
    If the card has a 4-byte UID it is probably a Mifare
    Classic card, and the following steps are taken:
    - Authenticate block 4 (the first block of Sector 1) using
      the default KEYA of 0XFF 0XFF 0XFF 0XFF 0XFF 0XFF
    - If authentication succeeds, we can then read any of the
      4 blocks in that sector (though only block 4 is read here)
    If the card has a 7-byte UID it is probably a Mifare
    Ultralight card, and the 4 byte pages can be read directly.
    Page 4 is read by default since this is the first 'general-
    purpose' page on the tags.
    This is an example sketch for the Adafruit PN532 NFC/RFID breakout boards
    This library works with the Adafruit NFC breakout
      ----> https://www.adafruit.com/products/364
    Check out the links above for our tutorials and wiring diagrams
    These chips use I2C to communicate
    Adafruit invests time and resources providing this open source code,
    please support Adafruit and open-source hardware by purchasing
    products from Adafruit!
#include <Wire.h>
#include <Adafruit_NFCShield_I2C.h>
#define IRQ   (2)
#define RESET (3)  // Not connected by default on the NFC Shield
Adafruit_NFCShield_I2C nfc(IRQ, RESET);
void setup(void) {
  nfc.begin();
    while (1); // halt
  Serial.print("Found chip PN5"); Serial.println((versiondata>>24) & 0xFF, HEX);
  Serial.print("Firmware ver. "); Serial.print((versiondata>>16) & 0xFF, DEC);
  Serial.print('.'); Serial.println((versiondata>>8) & 0xFF, DEC);
  nfc.SAMConfig();
  Serial.println("Waiting for an ISO14443A Card ...");
void loop(void) {
  uint8_t success;
  uint8_t uid[] = { 0, 0, 0, 0, 0, 0, 0 };  // Buffer to store the returned UID
  uint8_t uidLength;                        // Length of the UID (4 or 7 bytes depending on ISO14443A card type)
  // Wait for an ISO14443A type cards (Mifare, etc.).  When one is found
  // 'uid' will be populated with the UID, and uidLength will indicate
  // if the uid is 4 bytes (Mifare Classic) or 7 bytes (Mifare Ultralight)
  success = nfc.readPassiveTargetID(PN532_MIFARE_ISO14443A, uid, &uidLength);
  if (success) {
    // Display some basic information about the card
    Serial.println("Found an ISO14443A card");
    Serial.print("  UID Length: ");Serial.print(uidLength, DEC);Serial.println(" bytes");
    Serial.print("  UID Value: ");
    nfc.PrintHex(uid, uidLength);
    Serial.println("");
    if (uidLength == 4)
      // We probably have a Mifare Classic card ...
      Serial.println("Seems to be a Mifare Classic card (4 byte UID)");
      // Now we need to try to authenticate it for read/write access
      // Try with the factory default KeyA: 0xFF 0xFF 0xFF 0xFF 0xFF 0xFF
      Serial.println("Trying to authenticate block 4 with default KEYA value");
      uint8_t keya[6] = { 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF };
      // Start with block 4 (the first block of sector 1) since sector 0
      // contains the manufacturer data and it's probably better just
      // to leave it alone unless you know what you're doing
      success = nfc.mifareclassic_AuthenticateBlock(uid, uidLength, 4, 0, keya);
      if (success)
        Serial.println("Sector 1 (Blocks 4..7) has been authenticated");
        uint8_t data[16];
        // If you want to write something to block 4 to test with, uncomment
        // the following line and this text should be read back in a minute
        //memcpy(data, (const uint8_t[]){ 'a', 'd', 'a', 'f', 'r', 'u', 'i', 't', '.', 'c', 'o', 'm', 0, 0, 0, 0 }, sizeof data);
        //success = nfc.mifareclassic_WriteDataBlock (4, data);
        // Try to read the contents of block 4
        success = nfc.mifareclassic_ReadDataBlock(4, data);
        if (success)
          // Data seems to have been read ... spit it out
          Serial.println("Reading Block 4:");
          nfc.PrintHexChar(data, 16);
          Serial.println("");
          // Wait a bit before reading the card again
          Serial.println("Ooops ... unable to read the requested block.  Try another key?");
        Serial.println("Ooops ... authentication failed: Try another key?");
    if (uidLength == 7)
      // We probably have a Mifare Ultralight card ...
      Serial.println("Seems to be a Mifare Ultralight tag (7 byte UID)");
      // Try to read the first general-purpose user page (#4)
      Serial.println("Reading page 4");
      uint8_t data[32];
      success = nfc.mifareultralight_ReadPage (4, data);
      if (success)
        nfc.PrintHexChar(data, 4);
        Serial.println("");
        Serial.println("Ooops ... unable to read the requested page!?");
Both sketches use some external libraries. Please provide links to where you downloaded them. I expect them to be the most current version.
Here are the links of both the libraries!
http://www.seeedstudio.com/wiki/File:PN532_SPI_V2.zip
On the picture it seems that the ICSP connector is not populated on your board. Can you check if this is really the case? The ICSP connector is a 6-pin connector organized in two rows, located more or less in the middle between the two main rows of pins on the side where the hardware serial pins and the analog inputs are located. The Arduino won't see the shield if this connector is not populated.
i was having doubt of same thing so i soldered it today but same error after solder 6 icsp headers too!
Do all ICSP pins have connection to the Arduino board now? Have you checked that? It's necessary for the shield to work.
yeah! i checked connectivity of every pin of shield will board!
Can you make pictures again and post them?
thanks! i figured it out ! coz of some soldering problems it was throwing error bt not for SPI example it works bt same error for I2C example ..Pn532 didnt find!
inDataExchange function isnt listed in the SPI.cpp and it is listed in I2C.. so can i use inDataExchange with SPI mode?
and i have to connect anything else for I2C mode??
What do you mean by "listed"?
Maybe, you still didn't provide schematics for your RFID breakout, so we have no idea of how the chip is wired on it.
What kind of soldering problem? The chip onto the board? The board to the breadboard? And please use plain English ("coz", "bt", "i", non-native speakers, maybe even native ones, have to guess what that might mean).
