NFC/WAV project - RFID card, reads, plays audio, then will not read next card
I modified the babel fish project put out by adafruit. If there is no files on the SD card, each of the four cards I scan will read. So I can read card A, then B, then C, then D and the serial monitor shows the card number and that it is waiting for a card. Once I put the loaded SD card in, the serial monitor lists the files then waits for the card. I scan it, audio plays, then its says waiting for card as per normal. But another card shows no response.
This may be important. If I press the reset button on the wav shield serial says " Didn’t find PN53X board". However when I reset the arduino it starts up just fine and plays the one audio when a card is presented.
So not sure if this a code issue or something else. Thanks if anyone could help!
[/#include <WaveHC.h>
#include <WaveUtil.h>
#include <Wire.h>
#include <Adafruit_NFCShield_I2C.h>
#define IRQ 6 // this trace must be cut and rewired!
#define RESET 8
Adafruit_NFCShield_I2C nfc(IRQ, RESET);
SdReader card; // This object holds the information for the card
FatVolume vol; // This holds the information for the partition on the card
FatReader root; // This holds the information for the volumes root directory
FatReader file; // This object represent the WAV file for a pi digit or period
WaveHC wave; // This is the only wave (audio) object, since we will only play one at a time
* Define macro to put error messages in flash memory
#define error(msg) error_P(PSTR(msg))
//////////////////////////////////// SETUP
  // set up Serial library at 9600 bps
  PgmPrintln("Pi speaker");
  if (!card.init()) {
    error("Card init. failed!");
  if (!vol.init(card)) {
    error("No partition!");
  if (!root.openRoot(vol)) {
    error("Couldn't open dir");
  PgmPrintln("Files found:");
  root.ls();
  // find Adafruit RFID/NFC shield
  nfc.begin();
  uint32_t versiondata = nfc.getFirmwareVersion();
  if (! versiondata) {
    Serial.print("Didn't find PN53x board");
    while (1); // halt
  // Got ok data, print it out!
  Serial.print("Found chip PN5"); Serial.println((versiondata>>24) & 0xFF, HEX);
  Serial.print("Firmware ver. "); Serial.print((versiondata>>16) & 0xFF, DEC);
  Serial.print('.'); Serial.println((versiondata>>8) & 0xFF, DEC);
  // configure board to read RFID tags
  nfc.SAMConfig();
/////////////////////////////////// LOOP
unsigned digit = 0;
  uint8_t success;
  uint8_t uid[] = { 0, 0, 0, 0, 0, 0, 0 }; // Buffer to store the returned UID
  uint8_t uidLength; // Length of the UID (4 or 7 bytes depending on ISO14443A card type)
  // wait for RFID card to show up!
  Serial.println("Waiting for an ISO14443A Card ...");
  // Wait for an ISO14443A type cards (Mifare, etc.). When one is found
  // 'uid' will be populated with the UID, and uidLength will indicate
  // if the uid is 4 bytes (Mifare Classic) or 7 bytes (Mifare Ultralight)
  success = nfc.readPassiveTargetID(PN532_MIFARE_ISO14443A, uid, &uidLength);
  uint32_t cardidentifier = 0;
  if (success) {
    // Found a card!
    Serial.print("Card detected #");
    // turn the four byte UID of a mifare classic into a single variable #
    cardidentifier = uid[3];
    cardidentifier <<= 8; cardidentifier |= uid[2];
    cardidentifier <<= 8; cardidentifier |= uid[1];
    cardidentifier <<= 8; cardidentifier |= uid[0];
    Serial.println(cardidentifier);
  // repeat this for loop as many times as you have RFID cards
    if (cardidentifier == 3298252137) { // this is the card's unique identifier
      playcomplete("gold6.WAV"); // these are file names for the sample audio files - change them to your own file names
      if (cardidentifier == 3298507849) {
      playcomplete("orange6.WAV");
    if (cardidentifier == 3298236249) {
      playcomplete("blue6.WAV");
    if (cardidentifier == 3298252329) {
      playcomplete("green6.WAV");
/////////////////////////////////// HELPERS
* print error message and halt
void error_P(const char *str) {
  PgmPrint("Error: ");
  SerialPrint_P(str);
  sdErrorCheck();
  while(1);
* print error message and halt if SD I/O error
void sdErrorCheck(void) {
  if (!card.errorCode()) return;
  PgmPrint("\r\nSD I/O error: ");
  Serial.print(card.errorCode(), HEX);
  PgmPrint(", ");
  Serial.println(card.errorData(), HEX);
  while(1);
* Play a file and wait for it to complete
void playcomplete(char *name) {
  playfile(name);
  while (wave.isplaying);
  // see if an error occurred while playing
  sdErrorCheck();
* Open and start playing a WAV file
void playfile(char *name) {
  if (wave.isplaying) {// already playing something, so stop it!
    wave.stop(); // stop it
  if (!file.open(root, name)) {
    PgmPrint("Couldn't open file ");
    Serial.print(name);
    return;
  if (!wave.create(file)) {
    PgmPrintln("Not a valid WAV");
    return;
  // ok time to play!
  wave.play();
}code]
Just bumping this in case someone at this time in the morning has a thought. My concern is that it could possibly be a hardware issue? I've used this WAV shield before with two audio clips and a ultrasound distance detector to play either of the files based on the distance perceived. That worked, so now that I'm using it with a NFC adafruit shield it won't play more than one clip - that has me wondering...
ok - so I tried adding a reset - that worked in that it reset the board but it made the card not useable in how I need it to operate - since the rest takes the card out of the loop and sends it back to the start I have a few seconds when the reader is not looking for a card. Then I can't figure how to create the delay in the loop long enough as it resets after a second of audio...
So this to me is the problem area if its a code issue. After it detects a card and plays the audio, its makes it to: Serial.println(“Waiting for an ISO14443A Card …”);
Then freezes. new card, same card. nothing helps.
[/void loop() {
  uint8_t success;
  if (success) {
    // Found a card!
      playcomplete("gold6.WAV"); // these are file names for the sample audio files - change them to your own file namescode]
