Good evening!
I am trying to make a custom boost gauge using the 3.12" 256x64 SSD1322 display from New Haven using u8glib. The left half of the screen displays a static 128x64 bitmap, and the right half displays the PSI reading. Even while using Hardware SPI and a larger page height, the screen is not refreshing smooth enough for my liking.
The only three solutions I suppose are
- First draw the the bitmap on the left side, then switch the column start address to the middle of the screen so now it only has half as many pixels to refresh. (not sure if this is possible?)
- Same thing as above, but use two separate instances of u8g addressing each 128x64 halves of the display. (again, not sure if that’s possible)
- Run the display in parallel mode
Though to run in parallel mode would be the easiest solution, im having trouble figuring out how to run the display in parallel mode using u8glib. I tried setting the initial parameters as:
U8GLIB_NHD31OLED_2X_BW u8g(2, 3, 4, 5, 6, 7, 8, 9, 10, 11, U8G_PIN_NONE, U8G_PIN_NONE);
However it does not work. Just a blank screen.
Would greatly appreciate any help
