This isn't a question, I thought that others might find this interesting and keep it mind if they ever come across a similar need.
I had a need to control a 7 segment display which outputs 6 different functions. Using just one switch and Nick Gammon’s Class, SwitchManager.h I was able to easily achieve what I wanted.
You could easily use a similar process to create a menu structure application.
Thanks Nick
//See Nick Gammon's http://www.gammon.com.au/forum/?id=11955
//See reply #1 for the class ZIP file to download
// Setup:
//we have only one switch
//it is connected to input 4
//with only one switch we can detect what the user wants to do
//by simply looking at the current state of the switch (whether it is pushed or not)
//and how long it has been since the last push
#include <SwitchManager.h>
SwitchManager modeSW; // create the object
//just some stuff to make this example compile
const byte ModeSW = 4; //input from the Mode push button switch
byte modeNumber; //is the current # of the display mode
byte counter;
boolean flag;
int i;
int pulsesSent;
void setup ()
modeSW.begin (ModeSW, modeSwitchManager);
//check to see what's happening with the Mode switch
modeSW.check();
// M O D E S W I T C H M A N A G E R
// function looks after pushes on the Mode switch
void modeSwitchManager (const byte newState, const unsigned long interval)
// H I G H M O D E S W I T C H P U S H S E C T I O N
//is the new switch position HIGH and has it been that way for >= 1 second?
if (newState == HIGH && interval >= 1000UL)
// whatever code you want to execute, example clear a counter
counter = 0;
return;
//is the new switch position HIGH and has it been that way for < 1 second?
if (newState == HIGH)
return; //ignor the switch push or do what ever you need to do for this situation
// L O W M O D E S W I T C H P U S H S E C T I O N
//was the switch pressed for <= 1/4 second
//i.e. are we switching to a new mode?
if (interval <= 250)
modeNumber++;
//only go up to mode 6 maximum or whatever you need it to be for your application
if (modeNumber > 6)
modeNumber = 0;
//example of 6 differnt diplay modes. (on a LCD or 7 segment display)
//update to the new display mode
switch (modeNumber) //execute whatever code is necessary for each mode
case 0: //Input pulse counter displays CXXXXXXX
case 1: //Frequency counter displays FXXXXXXX
//if flag = true, means we can start counting
flag = true;
i = 0;
case 2: //High Pulse Width displays HXXXXXXX
//prepareForInterrupts ();
case 3: //Low Pulse Width displays LXXXXXXX
case 4: //Auto range voltmeter displays EXXXXXXX
case 5: //Pulse output 1X displays P1_XXXXX
//clear7219();
//start out at zero
//pulsesSent = 0UL;
case 6: //Pulse output 10X displays P10XXXXX
//clear7219();
//start out at zero
//pulsesSent = 0UL;
} // END of switch(mode)
return;
//Lets check for some different LOW Mode switch pushes
//if we are in modeNumber 5 and there was a switch push >= 3 seconds
//Have to wait initially 3 seconds then 1 sec there after
if (modeNumber == 5 && interval >=3000)
pulsesSent++;
//pulseOutput(1); //send 1 pulse out on the pulse probe
return;
//if we met the previous condition we now only have to wait 1 second to do the same thing
else if (modeNumber == 5 && pulsesSent > 0 && interval >=1000)
pulsesSent++;
return;
return;
} // END of modeSwitchManager()
