Hi everyone, I am trying to implement the following test code from this Arduino tutorial. I uploaded the NiclaShieldHost & NiclaShieldController sketches (Found in File>Examples>Arduino_Pro_Tutorials>Nicla Sense ME as a MKR Shield) to the Portenta & Nicla, resp....
NiclaShieldHost:
#include "Wire.h"
#define NICLA_I2C_ADDRESS 0x1A
void setup(){
while (!Serial);
Wire.begin(); // Join the I2C bus as a Host
Serial.println("Host started");
void loop(){
I2CWrite(1); // Request Acceleration X
int16_t acX = getData16();
I2CWrite(2); // Request Acceleration Y
int16_t acY = getData16();
I2CWrite(3); // Request Acceleration Z
int16_t acZ = getData16();
Serial.print("ACCELERATION :");
Serial.print(" X: ");
Serial.print(acX);
Serial.print(" Y: ");
Serial.print(acY);
Serial.print(" Z: ");
Serial.print(acZ);
delay(2500);
void I2CWrite(int command){
Wire.beginTransmission(NICLA_I2C_ADDRESS);
Wire.write(command);
Wire.endTransmission();
delay(100);
int16_t getData16(){
int16_t data = 0;
Wire.requestFrom(0x1A, 2);
while (Wire.available()){
for (int i = 0; i < 2; i++){
data |= Wire.read() << (8 * i);
return data;
NiclaShieldController:
#include "Nicla_System.h"
#include "Arduino_BHY2.h"
#include "Wire.h"
SensorXYZ accel(SENSOR_ID_ACC);
SensorXYZ gyro(SENSOR_ID_GYRO);
Sensor temp(SENSOR_ID_TEMP);
uint8_t command = 0x00;
void requestHandler(); //request event callback
void receiveEvent(int howMany); //receive event callback
void setup(){
BHY2.begin();
//Configure Sensors
accel.configure(1, 0);
gyro.configure(1, 0);
temp.configure(1, 0);
//Give LED feedback to the user
nicla::leds.begin();
nicla::leds.setColor(green);
Wire.begin(0x1A); // join i2c bus with address #0x1A , do not use 0x60 nor 0x6B, the MKR board has those i2c devices
Wire.onRequest(requestHandler); // Callback triggered from `Wire.requestFrom()` done by the Host
Wire.onReceive(receiveEvent); // Callback triggered from `Wire.beginTransmission()` done by the Host
void loop(){
BHY2.update(10);
void I2CWrite16(int16_t data){
Wire.write((byte)(data & 0xFF));
Wire.write((byte)((data >> 8) & 0xFF));
void receiveEvent(int howMany){
nicla::leds.setColor(blue);
command = Wire.read();
nicla::leds.setColor(off);
void requestHandler(){
int16_t dataX;
int16_t dataY;
int16_t dataZ;
switch (command){
//Update readings command
case 0:
case 1:
dataX = accel.x();
I2CWrite16(dataX);
Serial.println(accel.toString());
case 2:
dataY = accel.y();
I2CWrite16(dataY);
case 3:
dataZ = accel.z();
I2CWrite16(dataZ);
default:
In the linked tutorial, they attach the Nicla board as a shield but it also says that the example will work with the ESLOV (I2C connector) so I chose the latter.
My problem is that I'm getting 0 for all 3 accelerometer readings irrespective of testing motion...
10:30:50.675 -> Host started
10:30:52.881 -> ACCELERATION : X: 0 Y: 0 Z: 0
10:30:57.590 -> ACCELERATION : X: 0 Y: 0 Z: 0
10:31:02.346 -> ACCELERATION : X: 0 Y: 0 Z: 0
10:31:07.057 -> ACCELERATION : X: 0 Y: 0 Z: 0
10:31:11.799 -> ACCELERATION : X: 0 Y: 0 Z: 0
The Nicla is always showing solid green LED.
