Hello!
I'm experiencing a problem with BLE on NICLA SENSE ME.
(NICLA SENSE ME -> PC through Notify)
The issue is that the transmission rate is not consistent. I captured the packets using Wireshark and it showed that packets arrived inconsistently. The interval between the packets varied from 1ms to 50ms.
So I logged the execution time of my Arduino code and I found that the behavior of writeValue() is a bit strange.
The below is the execution time of writeValue() . The execution time fluctuates but somehow it seems that there's a kind of a pattern (2 short ones followed by a long one)
(unit in microsecond)
09:44:08.211 -> 30
09:44:08.211 -> 30
09:44:08.211 -> 29
09:44:08.244 -> 16465
09:44:08.244 -> 29
09:44:08.244 -> 29
09:44:08.277 -> 26197
09:44:08.277 -> 29
09:44:08.277 -> 29
09:44:08.344 -> 18755
09:44:08.344 -> 29
09:44:08.344 -> 29
09:44:08.377 -> 24714
09:44:08.377 -> 29
09:44:08.377 -> 29
09:44:08.443 -> 24819
09:44:08.443 -> 29
09:44:08.443 -> 29
09:44:08.476 -> 26612
09:44:08.476 -> 29
09:44:08.476 -> 29
09:44:08.543 -> 24605
09:44:08.543 -> 30
09:44:08.543 -> 29
09:44:08.576 -> 33216
09:44:08.576 -> 29
09:44:08.576 -> 29
09:44:08.663 -> 25791
09:44:08.663 -> 29
09:44:08.663 -> 29
09:44:08.663 -> 25248
So my questions are
- Has anyone had a similar issue like this?
- Is there a way to send data constantly over BLE? (as fast as possible)
Thank you!
This is my code:
#include "Nicla_System.h"
#include "Arduino_BHY2.h"
#include <ArduinoBLE.h>
#define BLE_SENSE_UUID(val) ("19b10000-" val "-537e-4f6c-d104768a1214")
const int VERSION = 0x00000000;
BLEService service(BLE_SENSE_UUID("0000"));
BLECharacteristic quaternionCharacteristic(BLE_SENSE_UUID("0003"), BLENotify, 4 * sizeof(float));
SensorQuaternion quaternion(SENSOR_ID_RV);
String name;
const long interval = 10;
unsigned long previousMillis = 0;
void setup(){
Serial.println("Start");
nicla::begin();
nicla::leds.begin();
nicla::leds.setColor(green);
//Sensors initialization
BHY2.begin();
quaternion.begin();
if (!BLE.begin()){
while (1)
String address = BLE.address();
address.toUpperCase();
name = "jsBLESense-";
name += address[address.length() - 5];
name += address[address.length() - 4];
name += address[address.length() - 2];
name += address[address.length() - 1];
BLE.setLocalName(name.c_str());
BLE.setDeviceName(name.c_str());
BLE.setAdvertisedService(service);
service.addCharacteristic(quaternionCharacteristic);
BLE.setEventHandler(BLEConnected, blePeripheralConnectHandler);
BLE.setEventHandler(BLEDisconnected, blePeripheralDisconnectHandler);
BLE.addService(service);
BLE.advertise();
void loop(){
while(BLE.connected()){
BHY2.update();
if (currentMillis - previousMillis >= interval) {
if(quaternionCharacteristic.subscribed()){
float x, y, z, w;
x = quaternion.x();
y = quaternion.y();
z = quaternion.z();
w = quaternion.w();
float quaternionValues[] = {x,y,z,w};
unsigned long start = micros();
quaternionCharacteristic.writeValue(quaternionValues, sizeof(quaternionValues));
unsigned long end = micros();
unsigned long delta = end - start;
Serial.println(delta);
void blePeripheralConnectHandler(BLEDevice central){
nicla::leds.setColor(blue);
void blePeripheralDisconnectHandler(BLEDevice central){
nicla::leds.setColor(red);
