Nicla Sense ME Orientation Problems
I have mounted a Nicla Sense ME on a simple platform, with USB on the underside of the board. I have setup a simple 15 sec logging program for the rotation (SENSOR_ID_RV). I have performed simple pitch, roll and heading directional movements in accordance with the X-Y-Z graphic on the top of the board, to try and orientate myself to the Nicla coordinate system. After logging the data at 100 Hz for 15 sec and porting the data to Excel using Putty, I normalized and converted the data to Euler angles in degrees using
// Normalize quaternion
double norm = sqrt(rot_W* rot_W+ rot_X* rot_X+ rot_Y* rot_Y+ rot_Z* rot_Z);
double invNorm = 1.0 / norm;
rot_W*= invNorm;
rot_X*= invNorm;
rot_Y*= invNorm;
rot_Z*= invNorm;
// Compute Euler angles in radians
roll = atan2(2 * (rot_W* rot_X+ rot_Y* rot_Z), 1 - 2 * (rot_X* rot_X+ rot_Y* rot_Y));
pitch = asin(2 * (rot_W* rot_Y- rot_Z* rot_X));
heading = atan2(2 * (rot_W* rot_Z+ rot_X* rot_Y), 1 - 2 * (rot_Y* rot_Y+ rot_Z* rot_Z));
// Convert to degrees
roll = roll * 180.0 / M_PI;
pitch = pitch * 180.0 / M_PI;
heading = heading * 180.0 / M_PI;
When I've reviewed the data in Excel, I find the following conclusions:
  • the X and Y axis as printed on the board are backwards. Pitch (normally rot_x) is rot_y, Roll (normally rot_y) is rot_x.
  • Pitch* (corrected) is 0° when USB is pointed downward, and +90° when laying flat on the table with USB on the underside
  • Roll* (corrected) is 0° when the board is laying flat on the table and the USB is on the underside
  • when USB is pointed north, heading is 90° (instead of 0°); when USB is pointed south, heading is -90° (instead of 180°); clockwise rotation moves the direction positively (+°)
Can you see any problems with what I am concluding? I'll admit I'm new at this. My sketch is below
 * This sketch is a stand-alone Nicla Sense ME app to
#include <Arduino_BHY2.h> // BHY2 sensor library
#include <Nicla_System.h> //Nicla system library
#include <LibPrintf.h> // Printf function library
#define FREQUENCY_HZ    (100) // 10 Hz
#define INTERVAL_MS     (1000 / FREQUENCY_HZ)
#define SAMPLE_NO       (1500)
#define ACCEL_RANGE     (4) // up to 4g
#define GYRO_RANGE      (2000) // up to 2000 dps
// Local variables
// SensorXYZ accel(SENSOR_ID_ACC); //returns xyz data
// SensorXYZ gyro(SENSOR_ID_GYRO); //returns xyz data
// SensorXYZ mag(SENSOR_ID_MAG); //returns xyz data
SensorQuaternion rot(SENSOR_ID_RV); //returns xyz data
SensorQuaternion orient(SENSOR_ID_ORI); //returns xyz data
static unsigned long printTime;
static unsigned int sampleCount = 0; // number of samples taken
bool dataCol = false; // New variable to track data collection status
  // Initialize Serial Port for debug info
  while(!Serial); //waits until serial com established before proceeding
  // Initialize Sensor Modules
  Serial.print("Initializing the sensors...");
    nicla::begin();
    nicla::leds.begin();
    BHY2.begin(NICLA_I2C);
    // accel.begin();
    // gyro.begin();
    // mag.begin();
    rot.begin();
    orient.begin();
  Serial.println("done");
  printTime = millis();
  // Print CSV header
  printf("timestamp, rot_X, rot_Y, rot_Z, rot_W, orient_x, orient_y, orient_z, orient_w, sampleCount\n");
  // Turn on LED to blinking yellow for 5 sec delay
  for (int i = 0; i < 10; i++) {
    nicla::leds.setColor(red);
    delay(500); // Yellow on for 0.5 seconds
    nicla::leds.setColor(off);
    delay(500); // Yellow off for 0.5 seconds
  // Change LED color to green and indicate data collection has started
  nicla::leds.setColor(green);
  dataCol = true;
  auto currentTime  = millis();
  // Update function should be continuously polled
  BHY2.update();
  // Set Interval Time and Check sensor values
  if (sampleCount < SAMPLE_NO && currentTime - printTime >= INTERVAL_MS) {
    printTime = currentTime;
    sampleCount++;
    printf("%lu,%.2f,%.2f,%.2f,%.2f,%.2f,%.2f,%.2f,%.2f,%d\n",
      printTime,
      rot.x(), rot.y(), rot.z(), rot.w(),
      orient.x(), orient.y, orient.z, orient.w(),
      sampleCount
  if (sampleCount >= SAMPLE_NO) {
    dataCol = false;
Please edit your post to add code tags (see the "How to get the best out of this forum" post for instructions, linked at the head of every forum category).
IMUs are useless for orientation unless the magnetometer and gyro are properly calibrated. Were any instructions for those procedures provided with the IMU library, and did you follow them?
Another potential issue is the failure to define an internal right handed coordinate system, consistent for all three sensors, and to define how that system, and the Earth frame (yaw, especially), is related to the axes printed on the sensor board.
Finally, whether these Euler angle conversions are correct depends on how the quaternion is defined with respect to the Earth frame. There are many different conventions.
It would be better to call the library routines to convert to Euler angles.
Thanks for the advice. Added code tags to post, and I'll look for proper calls for converting to Euler angles.
From what I've read, it appeared that the Nicla Sense SE came calibrated out of the box. Not so sure that's the case now. Anyone know of calibration routines for this board?
That is a Bosch sensor, with internal calibration routines that have never worked very well. You are supposed to check the calibration status (a library call), after waving the sensor around a bit.
It would be a good idea to read up a bit more on the sensor.
Edit: I looked more closely at the BHY2 library, and Bosch has really buried the calibration status checks. The function byh2_get_calibration_profile is available, but I don't know how useful it might be.
If you want accurate orientation data, Bosch IMU sensors are not the way to go. As far as I can tell, they are designed for tasks like determining whether a smart phone screen is in landscape or portrait orientation, but not much else.
