Hi, I have created a project for the classification of two objects using Arduino Nicla Vision.
In the Deployment phase, I selected “Arduino Library,” and the output was successful (unlike with Open MV, where the output failed due to memory issues).
I loaded the library into the Arduino IDE and selected the example for image acquisition with Nicla Vision for the classification of my objects.
Initially, the sketch compiled successfully, and I obtained the classification of my objects. However, upon retrying, I encountered issues (always with the same project). After uploading to the Arduino IDE, the output shows:
While in the serial monitor, I see:
Could you tell me why it worked fine initially but later I encountered these errors? What could be the reason for this? Thank you.
