Nicla Vision Eslov connector power pin seems not working
Can Nicla Vision Eslov connector (5V pin) provide power to an external I2C sensor? Or, it is only an input power pin? I have powered the Nicla Vision over USB connection and checked the voltage at Eslov connector 5V pin but it stays at 0V. It is not clear from the schematic that which side 5V pin is located (there is no label at the board) but the 5V pin and GND pin are at the opposite ends (in the schematic) so I checked both ways.
I gather you have not read the instructions and or do not understand them. Post the link to the Eslov, giving technical information and possibly a schematic. The schematic more than likely is not oriented the same way as the board. you state: "I checked both ways". Since I did not watch you what exactly did you do and how did you do it. I cannot answer on the sensor as I do not know what sensor you are talking about and what its requirements are. Post a link to technical information on the sensor as well. Where is the Arduino in all of this?
