Something like this?:
Arduino Access Point Server => PC Matlab Decoder and image show
Arduino INO:
#include <camera.h>
#include <WiFi.h>
#include <WiFiClient.h>
#include <WiFiSSLClient.h>
#include <WiFiServer.h>
#include <WiFiUdp.h>
// On Nano RP2040 Connect, RGB leds are connected to the wifi module
// The user APIs are the same, but we can't convert to int, so use defines
#if defined(ARDUINO_NANO_RP2040_CONNECT)
#include "WiFiNINA.h"
#define led1 LEDR
#define led2 LEDG
#define led3 LEDB
// On Nicla Sense ME, RGB leds are connected via an I2C module
#elif defined(ARDUINO_NICLA)
#include "Nicla_System.h"
#define led1 LEDR
#define led2 LEDG
#define led3 LEDB
#else
int led1 = LEDR;
int led2 = LEDG;
int led3 = LEDB;
#endif
//Camera Picture Values
FrameBuffer fb;
unsigned long lastUpdate = 0;
unsigned long StartTime = 0;
unsigned long StartTimeMeas = 0;
unsigned long PicTimer = 0;
unsigned long DeltaTime = 0;
bool PictureStatus_allowtakePicture = true;
bool PictureStatus_allowsendPicture = false;
bool toggleLEDR;
//Camera input
#ifdef ARDUINO_NICLA_VISION
#include "gc2145.h"
GC2145 galaxyCore;
Camera cam(galaxyCore);
#define IMAGE_MODE CAMERA_GRAYSCALE //normal CAMERA_RGB565
#else
#include "himax.h"
HM01B0 himax;
Camera cam(himax);
#endif
//Server
///////please enter your sensitive data in the Secret tab/arduino_secrets.h
char ssid[] = "NiclaVision"; // your network SSID (name)
char pass[] = "123Qwerty"; // your network password (use for WPA, or use as key for WEP)
int keyIndex = 0; // your network key Index number (needed only for WEP)
int status = WL_IDLE_STATUS;
WiFiServer server(80);
bool GET_Req_StBit_detected = false;
bool GET_Req_Picture_detected = false;
bool GET_Req_INFOS_detected = false;
Serial.begin(1000000); //921600
Serial.println("Access Point Web Server");
// by default the local IP address of will be 192.168.3.1
// you can override it with the following:
// WiFi.config(IPAddress(10, 0, 0, 1));
// The AP needs the password be at least 8 characters long
if (strlen(pass) < 8) {
Serial.println("Creating access point failed");
Serial.println("The WiFi password must be at least 8 characters long");
// don't continue
while (true);
// print the network name (SSID);
Serial.print("Creating access point named: ");
Serial.println(ssid);
//Create the Access point
status = WiFi.beginAP(ssid, pass);
if (status != WL_AP_LISTENING) {
// don't continue
while (true);
// wait 10 seconds for connection:
Serial.println("Waiting 10s for Connection");
// start the web server on port 80
server.begin();
// you're connected now, so print out the status
printWiFiStatus();
if (!cam.begin(CAMERA_R320x240, CAMERA_GRAYSCALE, 30)) { //QVGA Resolution: CAMERA_R320x240 or R640x480| IMAGE_MODE CAMERA_RGB565 | framerate by default begin(int32_t resolution=CAMERA_R320x240, int32_t pixformat=CAMERA_GRAYSCALE, int32_t framerate=30);
Serial.println("Camera no Start");
} //CAMERA_R640x480
else Serial.println("Camera Start");
//Take first Pichture
// Time out after 40 and send new data
// Grab 1st frame and write to fb
cam.grabFrame(fb, 40); //FrameBuffer &fb, uint32_t timeout
// Setup the 3 pins as OUTPUT undschalte LEDs aus
pinMode(LEDR, OUTPUT);
pinMode(LEDG, OUTPUT);
pinMode(LEDB, OUTPUT);
digitalWrite(LEDR, HIGH);
digitalWrite(LEDG, HIGH);
digitalWrite(LEDB, HIGH);
//Webside
WiFiClient client = server.available(); // listen for incoming clients
if (client) { // if you get a client,
Serial.println("new client"); // print a message out the serial port
String currentLine = ""; // make a String to hold incoming data from the client
StartTime = millis();
while (client.connected()) { // loop while the client's connected
if (millis() - StartTime >= 3000) {
Serial.print("<<< Timeout >>>>");
Serial.println(millis() - StartTime);
if (PictureStatus_allowtakePicture) {
TakePicture_Function();
//Serial.println("Client Connected");
if (client.available()) // if there's bytes to read from the client, &&PictureStatus_allowsendPicture
char c = client.read(); // read a byte read bytes from the incoming client
//Serial.print(c);
if (c == '\n') // if the byte is a newline character\n //if HTTP request has ended
{ // if the current line is blank, you got two newline characters in a row.
if (currentLine.length() == 0)
{ // Ende des GEt REquests erkannt
// Answer depending on Status
if (PictureStatus_allowsendPicture) {
digitalWrite(LEDR, LOW);
Serial.println("Send Picture");
Respond_Picture(client);
Serial.println("<<<<<Picture sended >>>>>>");
else {
digitalWrite(LEDG, LOW);
Serial.println("Send Status");
Respond_StBit(client);
Serial.println("<<<<<Status Answer sended >>>>>>");
else { // if you got a newline, then clear currentLine:
currentLine = "";
else if (c != '\r') { // if you got anything else but a carriage return character,
currentLine += c; // add it to the end of the currentLine
} //ende While
// close the connection:
delay(20);
client.flush();
client.stop();
digitalWrite(LEDG, HIGH); // Client not avaliable
Serial.println("client disconnected");
void printWiFiStatus() {
// print the SSID of the network you're attached to:
Serial.print("SSID: ");
Serial.println(WiFi.SSID());
// print your WiFi shield's IP address:
IPAddress ip = WiFi.localIP();
Serial.print("IP Address: ");
Serial.println(ip);
// print where to go in a browser:
Serial.print("To see this page in action, open a browser to http://");
Serial.println(ip);
void TakePicture_Function() {
//IMU and Pictures
//HERE Picture
Serial.println("InI Snapshot");
if (PictureStatus_allowtakePicture) //Picture is only allowed when get Picture is made
{ if (cam.grabFrame(fb, 60) == 0) //FrameBuffer &fb, uint32_t timeout ==0 wenn neuer FRame da ist => Framerate für VGA 200
{ //Serial.println("Camera Photoshot");
PictureStatus_allowsendPicture = true;
PictureStatus_allowtakePicture = false;
Serial.println("<<<<< Snapshot >>>>>>");
void Respond_StBit( WiFiClient client) {
client.println("Content-type:multipart/byteranges"); //multipart/byteranges
client.println("Content-Length: 1");
client.println("Connection: close");
client.println();
client.println("<html>");
client.write(PictureStatus_allowsendPicture);
client.println("</html>");
//client.println("\r");
client.println();
void Respond_Picture( WiFiClient client) {
//https://mothereff.in/byte-counter
client.println("Content-Length: 76800"); //multipart/byteranges bei QVGA RGB 153600 bei VGA 614400bytes + Headereoffset after OK 153673 ||| Grayscale QVGA 76800 = over all 76814 für VGA 307200
client.println();
client.println("<html>"); //<body>
client.write(fb.getBuffer(), cam.frameSize()); //cam.frameSize()
client.println("</html>"); //</body>
client.println();
Matlab decoder:
clc
clear
import matlab.net.*
import matlab.net.http.*
i=true;
options_GET = weboptions('UserAgent','','Timeout',Inf);
URI=matlab.net.URI('http://192.XXX.'); % see serial Monitor
while 1
tic
while i
answer=webread(URI, options_GET);
if length(answer) >= 76700
i=false;
end
end
web_PIC=answer;
web_vector_withheader = web_PIC.';
web_vector = web_vector_withheader(1:end); %cut header away //27 -14
web_vector = circshift(web_vector, -14); % Versatz Bild hoch und Runter vertikal aus <html><body>
grey_img=reshape(web_vector,[320,240] ); %[320,240] [640,480]
imshow(flipdim(grey_img,2)); % title('grey IMG');
i=true;
toc
end
Make shure you installed the Wifi Firmware Updater before, below examples/ Stm32..._System/Wifi FrimwareUpdater and installed it completely. Control Flash Status on serial Monitor (2x 100%)
