Nicla Vision Wifi Updater
Which Place ist the WIFI Firmware using, there is a comment with
// use space from 15.5MB to 16 MB for another fw, memory mapped
mbed::MBRBlockDevice::partition(&root, 1, 0x0B, 0, 1024 * 1024 ); //
#include "QSPIFBlockDevice.h"
#include "MBRBlockDevice.h"
#include "FATFileSystem.h"
#include "wiced_resource.h"
#include "certificates.h"
#ifndef CORE_CM7
  #error Update the WiFi firmware by uploading the sketch to the M7 core instead of the M4 core.
#endif
QSPIFBlockDevice root(QSPI_SO0, QSPI_SO1, QSPI_SO2, QSPI_SO3,  QSPI_SCK, QSPI_CS, QSPIF_POLARITY_MODE_1, 40000000);
mbed::MBRBlockDevice wifi_data(&root, 1);
mbed::FATFileSystem wifi_data_fs("wlan");
long getFileSize(FILE *fp) {
    fseek(fp, 0, SEEK_END);
    int size = ftell(fp);
    fseek(fp, 0, SEEK_SET);
    return size;
void printProgress(uint32_t offset, uint32_t size, uint32_t threshold, bool reset) {
  static int percent_done = 0;
  if (reset == true) {
    percent_done = 0;
    Serial.println("Flashed " + String(percent_done) + "%");
    uint32_t percent_done_new = offset * 100 / size;
    if (percent_done_new >= percent_done + threshold) {
      percent_done = percent_done_new;
  while (!Serial);
  // Create a partition WHYYY 15MB!!!???????
  int err =  wifi_data_fs.mount(&wifi_data);
  if (err) {
    // Reformat if we can't mount the filesystem
    // this should only happen on the first boot
    Serial.println("No filesystem containing the WiFi firmware was found.");
    Serial.println("Usually that means that the WiFi firmware has not been installed yet"
                  " or was overwritten with another firmware.\n");
    Serial.println("Formatting the filsystem to install the firmware and certificates...\n");
    err = wifi_data_fs.reformat(&wifi_data);
  DIR *dir;
  struct dirent *ent;
  if ((dir = opendir("/wlan")) != NULL) {
    /* print all the files and directories within directory */
    while ((ent = readdir (dir)) != NULL) {
      Serial.println("Searching for WiFi firmware file " + String(ent->d_name) + " ...");
      String fullname = "/wlan/" + String(ent->d_name);
      if (fullname == "/wlan/4343WA1.BIN") {
        Serial.println("A WiFi firmware is already installed. "
                       "Do you want to install the firmware anyway? Y/[n]");
        while (1) {
          if (Serial.available()) {
            int c = Serial.read();
            if (c == 'Y' || c == 'y') {
            if (c == 'N' || c == 'n') {
              return;
    closedir (dir);
  extern const unsigned char wifi_firmware_image_data[];
  extern const resource_hnd_t wifi_firmware_image;
  FILE* fp = fopen("/wlan/4343WA1.BIN", "wb");
  const int file_size = 421098;
  int chunck_size = 1024;
  int byte_count = 0;
  Serial.println("Flashing /wlan/4343WA1.BIN file");
  printProgress(byte_count, file_size, 10, true);
  while (byte_count < file_size) {
    if(byte_count + chunck_size > file_size)
      chunck_size = file_size - byte_count;
    int ret = fwrite(&wifi_firmware_image_data[byte_count], chunck_size, 1, fp);
    if (ret != 1) {
      Serial.println("Error writing firmware data");
    byte_count += chunck_size;
    printProgress(byte_count, file_size, 10, false);
  fclose(fp);
  chunck_size = 1024;
  byte_count = 0;
  const uint32_t offset = 15 * 1024 * 1024 + 1024 * 512;
  Serial.println("Flashing memory mapped firmware");
    int ret = root.program(wifi_firmware_image_data, offset + byte_count, chunck_size);
    if (ret != 0) {
  chunck_size = 128;
  byte_count = 0;
  fp = fopen("/wlan/cacert.pem", "wb");
  Serial.println("Flashing certificates");
  printProgress(byte_count, cacert_pem_len, 10, true);
  while (byte_count < cacert_pem_len) {
    if(byte_count + chunck_size > cacert_pem_len)
      chunck_size = cacert_pem_len - byte_count;
    int ret = fwrite(&cacert_pem[byte_count], chunck_size, 1 ,fp);
    if (ret != 1) {
      Serial.println("Error writing certificates");
    printProgress(byte_count, cacert_pem_len, 10, false);
  fclose(fp);
  fp = fopen("/wlan/cacert.pem", "rb");
  char buffer[128];
  int ret = fread(buffer, 1, 128, fp);
  Serial.write(buffer, ret);
  while (ret == 128) {
  fclose(fp);
  Serial.println("\nFirmware and certificates updated!");
  Serial.println("It's now safe to reboot or disconnect your board.");
In Line 110there is a defined offset
which is used in line 117
But it now makes no sense with the partition postition and the QSPI Example. It is only placed somewere on the QSPI Flash
I found the QSPIFormat Example. It describes the 3 partitions for QSPI Storage:
    mbed::MBRBlockDevice::partition(&root, 1, 0x0B, 0, 1024 * 1024);
    if(default_scheme) {
      mbed::MBRBlockDevice::partition(&root, 3, 0x0B, 14 * 1024 * 1024, 14 * 1024 * 1024);
      mbed::MBRBlockDevice::partition(&root, 2, 0x0B, 1024 * 1024, 14 * 1024 * 1024);
      mbed::MBRBlockDevice::partition(&root, 2, 0x0B, 1024 * 1024, 6 * 1024 * 1024);
      mbed::MBRBlockDevice::partition(&root, 3, 0x0B, 6 * 1024 * 1024, 14 * 1024 * 1024);
So now it is clear how the storage space is used. My next question is how the workflow was planed from arduino.
Do I have to include the WIFI FirmwareUpdater in my code to store it on the first MB of QSPI or can I upload it seperately in the first patition. I Want to Store Userdata in the second partition without owerwriting the WIFI Firmware.
