Is there any way to connect Nicla Vision with this Waveshare IPS SPI Display? Or any other IPS Displays?
The tech specs in your Nicla Vision link say it supports SPI. Looks like you'll want to run it at 3.3v. The display wiki has Arduino example code. You'll have to adjust the pins accordingly.
Can you please provide some useful links to get started?
I don't know anything about either device, but if you look at the Arduino pin out in the example on the Waveshare link it shows how it is connected to the Arduino, and what they each do. https://robu.in/arduino-pin-configuration/ shows what those pins are for SPI, and your Nicla Vision link shows what the pins are on your hardware. I'd definitely start with a breadboard because you might have to experiment some.
