#include <Arduino.h>
#include <BluetoothSerial.h>
#include <L298N.h>
// #include <WiFi.h>
// #include <AsyncTCP.h>
// #include <ESPAsyncWebServer.h>
// #include <AsyncElegantOTA.h>
#include <NimBLEDevice.h>
#include <NimBLECharacteristic.h>
NimBLEDevice ble_device;
NimBLECharacteristic mycharacteristic;
BluetoothSerial bt;
const unsigned int IN1_A = 12;
const unsigned int IN2_A = 13;
const unsigned int IN3_B = 14;
const unsigned int IN4_B = 27;
const unsigned int IN5_C = 26;
const unsigned int IN6_C = 25;
const unsigned int IN7_D = 33;
const unsigned int IN8_D = 32;
L298N motor1(IN1_A,IN2_A);
L298N motor2(IN3_B,IN4_B);
L298N motor3(IN5_C,IN6_C);
L298N motor4(IN7_D,IN8_D);
void qianjin(){ //前进
motor1.forward();
motor2.forward();
motor3.forward();
motor4.forward();
void houtui(){ //后退
motor1.backward();
motor2.backward();
motor3.backward();
motor4.backward();
void zuopiaoyi(){ //左漂移
motor1.backward();
motor2.forward();
motor3.forward();
motor4.backward();
void youpiaoyi(){ //右漂移
motor1.forward();
motor2.backward();
motor3.backward();
motor4.forward();
void shache(){ //刹车
motor1.stop();
motor2.stop();
motor3.stop();
motor4.stop();
void youzhuan(){ //右转
motor1.forward();
motor3.forward();
void zuozhuan(){ //左转
motor1.backward();
motor3.backward();
void yuandixuanzhuan(){ //原地旋转
motor1.forward();
motor2.backward();
motor3.forward();
motor4.backward();
ble_device.init();
mycharacteristic.getUUID();
pinMode(13, OUTPUT);
pinMode(12, OUTPUT);
pinMode(14, OUTPUT);
pinMode(27, OUTPUT);
pinMode(26, OUTPUT);
pinMode(25, OUTPUT);
pinMode(33, OUTPUT);
pinMode(32, OUTPUT);
if (mycharacteristic.getDataLength() > 0) {
mycharacteristic.getValue();
Serial.println(mycharacteristic.getValue());
src/main.cpp:18:19: error: no matching function for call to 'NimBLECharacteristic::NimBLECharacteristic()'
BLECharacteristic NimBLECharacteristic;
In file included from .pio/libdeps/esp32dev/NimBLE-Arduino/src/NimBLEService.h:22,
from .pio/libdeps/esp32dev/NimBLE-Arduino/src/NimBLEServer.h:33,
from .pio/libdeps/esp32dev/NimBLE-Arduino/src/NimBLEDevice.h:38,
from src/main.cpp:8:
.pio/libdeps/esp32dev/NimBLE-Arduino/src/NimBLECharacteristic.h:71:5: note: candidate: 'NimBLECharacteristic::NimBLECharacteristic(const NimBLEUUID&, uint16_t, uint16_t, NimBLEService*)'
NimBLECharacteristic(const NimBLEUUID &uuid,
.pio/libdeps/esp32dev/NimBLE-Arduino/src/NimBLECharacteristic.h:71:5: note: candidate expects 4 arguments, 0 provided
.pio/libdeps/esp32dev/NimBLE-Arduino/src/NimBLECharacteristic.h:65:5: note: candidate: 'NimBLECharacteristic::NimBLECharacteristic(const char*, uint16_t, uint16_t, NimBLEService*)'
NimBLECharacteristic(const char* uuid,
.pio/libdeps/esp32dev/NimBLE-Arduino/src/NimBLECharacteristic.h:65:5: note: candidate expects 4 arguments, 0 provided
.pio/libdeps/esp32dev/NimBLE-Arduino/src/NimBLECharacteristic.h:63:7: note: candidate: 'NimBLECharacteristic::NimBLECharacteristic(const NimBLECharacteristic&)'
class NimBLECharacteristic {
.pio/libdeps/esp32dev/NimBLE-Arduino/src/NimBLECharacteristic.h:63:7: note: candidate expects 1 argument, 0 provided
src/main.cpp: In function 'void setup()':
src/main.cpp:121:3: error: 'mycharacteristic' was not declared in this scope
mycharacteristic.
src/main.cpp:121:3: note: suggested alternative: 'BLECharacteristic'
mycharacteristic.
BLECharacteristic
src/main.cpp: In function 'void loop()':
src/main.cpp:142:7: error: 'mycharacteristic' was not declared in this scope
src/main.cpp:142:7: note: suggested alternative: 'BLECharacteristic'
BLECharacteristic
*** [.pio\build\esp32dev\src\main.cpp.o] Error 1
Please can you also paste your code in code tags too.
b707
4
You can't define an "empty" characteristic, it should be created and initializated by createCharacteristic()
method:
BLECharacteristic *pCharacteristic = pService->createCharacteristic(
CHARACTERISTIC_UUID,
NIMBLE_PROPERTY::READ |
NIMBLE_PROPERTY::WRITE
See the manual:
https://h2zero.github.io/esp-nimble-cpp/md__migration_guide.html#characteristics
https://h2zero.github.io/esp-nimble-cpp/class_nim_b_l_e_characteristic.html
I have never used pointers and cannot instantiate them. How can I use the other functions in the class?
system
Closed
6
