Hello, guys!
I've been building an electric longboard around some NiMH batteries left after my Honda Civic Hybrid battery reconditioning. You know, the big fat battery that powers the engine. It is made out of 11 "pairs" or "sticks", 6500mAh 12cells each. The awesome part about them - they can give out 100A quite easily.
Anyhow, I'm half-through in building the board and I think it's pretty lame to use bench power supply to charge the battery in such a mobile project. So I thought of building a charger for it. The general advice my engineering friends gave me was "don't go for arduino, go for special NiMH charging ICs". Okay, I've researched a bit and found out that there are exactly none ICs that support >20 cells nimh. Famous MAX713 only supports UP TO 20 cells, and I'm planning to use 2 "sticks", that makes 24cell battery.
I need your good advice, people. I'm more of a programming guy and had C- in physics, so I kinda feel lost about this task.
Maybe I should just stick with MAX713 x2 for each stick?.. Although, sticks are connected in series so that would mean some kind of tricky switch needed.
Thanks!
