Nintendo DS Touchscreen Problems
Hey all,
I’m having a problem with the Nintendo DS Touchscreen I bought.
Here is how I have it wired. I bought the DS breakout board, so the Nintendo DS Pin number listed below is the breakout board pin number:
Arduino Mega Pin: Nintendo DS Pin:
Analog 2 X2
Analog 3 Y1
Analog 4 X1
Analog 5 Y2
Here is the sketch:
#define Lo 2
#define Bo 3
#define Ro 4
#define To 5
#define Ti 3
#define Ri 4
#define LED 13
int touchX = 0;
int touchY = 0;
  pinMode(LED, OUTPUT);
void loop ()
  if (touched())
    Serial.print ("X = ");
    Serial.print (touchX);
    Serial.print (" Y = ");
    Serial.println (touchY);
    digitalWrite (LED, HIGH);
    delay (50);
    digitalWrite (LED, LOW);
boolean touched()
  boolean touch = false;
  // HORIZONTAL ROUTINE!  SET L TO GND AND R TO 5V
  // Set L to GND:
  pinMode(Lo, OUTPUT);
  digitalWrite(Lo, LOW);
  // Set R to 5V:
  pinMode(Ro, OUTPUT);
  digitalWrite(Ro, HIGH);
  // Read the Bottom and Make the Top floating.  To set the top floating, make it an input
  pinMode(To, INPUT);
  pinMode(Bo, INPUT);
  delay(10);
  touchX = analogRead(Ti);
  // VERTICAL ROUTINE!  SET T TO GND AND B TO 5v
  //Set Bottom to 5V:
  pinMode(Bo, OUTPUT);
  pinMode(Bo, HIGH);
  //Set Top to GND:
  pinMode(To, OUTPUT);
  pinMode(To, LOW);
  //Read the Right Side and leave the Left Side floating.  To set the Left floatng, make it an input
  pinMode(Lo, INPUT);
  pinMode(Ro, INPUT);
  delay(10);
  touchY = analogRead(Ri);
  if(touchX < 1000 && touchY < 1000)
    touch = true;
  return touch;
The problem I’m having is the Serial Monitor just puts out X and Y coordinates constantly, even when the touchscreen is not being touched. Indeed, it continues to put out numbers even when I have the touchscreen unplugged from the Mega. I’m really confused here. :-/
OK, I copied the code from a website, and I found a couple of potential problems with the code, so I rewrote it to this:
int Lo = 3;
int Bo = 4;
int Ro = 5;
int To = 2;
int Bi = 4;
int Ri = 5;
int ledPin = 13;
int touchX = 0;
int touchY = 0;
  pinMode(ledPin, OUTPUT);
void loop ()
  if (touched())
    digitalWrite (ledPin, HIGH);
    delay (50);
    digitalWrite (ledPin, LOW);
boolean touched()
  // Set L to GND:
  // Set R to 5V:
  pinMode(To, INPUT);
  pinMode(Bo, INPUT);
  delay(10);
  touchX = analogRead(Bi);
  //Set Bottom to GND:
  pinMode(Bo, LOW);
  //Set Top to 5V:
  pinMode(To, HIGH);
  pinMode(Lo, INPUT);
  pinMode(Ro, INPUT);
  delay(10);
    touch = true;
  return touch;
And I changed the pinout accordingly:
Mega Pin: Breakout Pin:
Analog 2 Y1
Analog 3 X2
Analog 4 Y2
Analog 5 X1
Still behaves the same. Here are some experimental results:
  1. I decreased the threshold of touchX and touchY to various values, and the Serial Monitor will only display values below that threshold, but it still displays numbers without touching the screen and even when the touchscreen is disconnected from the Mega.
  2. When I increase the delay functions, the Serial Monitor still outputs values as described above, but at a slower pace.
  3. I decreased the threshold of touchX and touchY to 50, and the Serial Monitor does not output anything, even when I am touching the touchscreen with any amount of force, including more force than I feel comfortable with. I moved to various locations around the TS with no results.
Finally, a little piece of background info about the breakout board. When I received it, I inspected it and found that X2 and Y2 were shorted together with a bad solder job. I have learned over the years to inspect solder work before installing anything. As a result, I desoldered the pins and removed the short-circuit. I am confident that they are no longer short-circuited at te SMT solder point, but I did not take the connector apart and check it out.
Incidentally, Pins 25 and 26 on the FTDI chip of my Mega have a similar solder bridge across them, but they are common to GND anyway… :wink:
I did this ages ago....
I used this code: http://mnicolato.altervista.org/arduino/ardtouch.htm
The 'top' and 'right' also have to be connected to analog inputs with the others being connected to digital outputs for power...
Mowcius
I thought the analog pins could also be used as digital pins?
Anyway…I’ll try out your wiring tonight.
Mega Pin: Breakout Board Pin: TS Pin: Description:
Analog2 X1 1 Top of TS
Digital3 X2 3 Bottom of TS
Digital4 Y2 2 Left side of TS
Analog5 Y1 4 Right side of TS
Yes they can but you need them connected to two different pins.
From the site I linked. The top and right connections have to be connected to both analog and digital. You need 6 pins in total.
** Wiring Logic** Touchpad Arduino Phase 1: Phase 2: X axis reading Y axis reading
Left Dig 2 mode OUTPUT mode INPUT value: LOW (high impedance)
Top An 3 Read X axis value (not used) (last operation)* Dig 5 mode INPUT mode OUTPUT (high impedance) value: HIGH
Right An 4 (not used) Read Y axis value (last operation)* Dig 4 mode OUTPUT mode INPUT value: HIGH (High impedance)
Bottom Dig 3 mode INPUT mode OUTPUT (high impedance) value: LOW
[edit]That didn't copy well. Look at the site I linked for a better version.[/edit]
Mowcius
Oh! I'm tracking you now.
I looked at that site you referenced when I started this (in fact, I used the code from there and modified it a little), but unfortunately the translation made it pretty difficult to really understand what the guy was doing, but now that I understand that there will actually be six wires used, I think some of the blanks are beginning to be filled in.
I'll take a look at it again, and post another pin arrangement and will experiment with it tonight.
Thanks a lot, Mowcius.
I'm using a uOLED display with a 4-wire touch screen I added to it, you don't have to use the extra digital pins, you can use the analog pins as digital out instead. Port Pin Function PF 0 54 A0 PF 1 55 A1 PF 2 56 A2 PF 3 57 A3 PF 4 58 A4 PF 5 59 A5 PF 6 60 A6 PF 7 61 A7 PK 0 62 A8 PK 1 63 A9 PK 2 64 A10 PK 3 65 A11 PK 4 66 A12 PK 5 67 A13 PK 6 68 A14 PK 7 69 A15
