Nintendo DS ToushScreen: why "y" is alwa
i have connected a Nintendo DS TouchScreen to my Arduino duemilanove and i’m able to get only the x axis value, while the Y value is always 0 (zero).
Naturally i have read a lot of stuff on the web and tried a lot of scripts and connections (i’m not so good in electronic stuff so I often get inspiration from web) and it seems other people had the same problems.
Following the last source code I used :
//modified to match my sparkfun connector
#define xLow  17
#define xHigh 15
#define yLow  16
#define yHigh 14
void setup(){
void loop(){
  pinMode(xLow,OUTPUT);
  pinMode(xHigh,OUTPUT);
  digitalWrite(xLow,LOW);
  digitalWrite(xHigh,HIGH);
  digitalWrite(yLow,LOW);
  digitalWrite(yHigh,LOW);
  pinMode(yLow,INPUT);
  pinMode(yHigh,INPUT);
  delay(10);
  //xLow has analog port -14 !!
  int x=analogRead(yLow -14);
  pinMode(yLow,OUTPUT);
  pinMode(yHigh,OUTPUT);
  digitalWrite(yHigh,HIGH);
  digitalWrite(xHigh,LOW);
  pinMode(xLow,INPUT);
  pinMode(xHigh,INPUT);
  delay(10);
  int y=analogRead(xLow - 14);
    Serial.print(x,DEC);
    Serial.print(",");
    Serial.println(y,DEC);
  delay(200);
Connections
I used four 10K resistors connecting every pin to ground
A0 → x1
A1 → y2
A2 → x2
A3 → y1
Thanks in advance
Fabio
I'm no expert, but maybe you should check out this thread:
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1243499684
for wiring information and programming info..
Yep, I was going to post you to my thread as well :smiley:
The original page I used code from may also help you:
http://translate.google.co.uk/translate?hl=en&sl=auto&tl=en&u=http%3A%2F%2Fmnicolato.altervista.org%2Farduino%2Fardtouch.htm
If that code does not want to work then you have your connections wrong!
Any more questions, just ask :smiley:
Mowcius
thanx guys! :slight_smile:
I had already tested and read these links too but if you are 100%sure that it works I'll try them again :slight_smile:
Are you? Please, be honest : D
Fabio
Yep, I am sure that the basic code from marco nicolato works right out the box becuase I have used it like that. Try his code, you don't need any resistors/ it is simpler :wink:
Hope you get it working...
Mowcius
Thanx a lot mowcius, i'll do my best : )
