I've successful run and debuged a simple c code on a nios ii implemented into vidor 4000's cyclone 10
using on chip ram ( 120 mhz ) with vidor jtag emulator .
How can i use sdram controller to use the external ram chip with a nios cpu ?
The attached picture shows my qsys setup for sdram and nios
Your setup seems fine and SDRAM should already be visible from nios. If you have trouble with that likely your parametrization of the sdram controller is not ok. Please start from the qsys we provide with graphics project on GitHub.
Also I suggest you start with 100mhz as you may have trouble closing timings at higher speeds...
If you don't have Quastus license then I recommend to use ARM with JTAG-AvalonMM bridge to FPGA.
That Nios II e is pretty slow and without hardware mult/div.
Nios II f without license will create timelimited bitfile. I think if you use arm as usb blaster and it's connected to computer then it's fine. 1h timer starts after it lost connection to quartus programmer software. Using commandline tool you can also establish serial connection to Nios II and 1h timer should starts after serial connection is closed.
Thank you very much for your answer .
i have not been able to make it work even with a 24 mhz or 100 mhz clock signal .
I've tried to build the project from github vidor repository , but some components seem to be missing in altera quartus lite (nina uart and qspi ) .
the suggested qsys (graphics ) has the sdram controller is connected to a sdram arbitrer instead of cpu and,if i'm not wrong, only data bus is connected .
I guess you didn't follow the readme on GitHub which instructs on how to patch quartus so that you have the missing blocks. In any case if you're using quartus lite you should use the lite version of the qsys which also uses nios e which is free whereas nios f is not.
Regarding connections you can remove arbiter and connect directly nios to sdram. The reason for the arbiter is that it removes some over listed fabric from qsys and at the same time provides some prioritization to allow video small to have higher precedence than could but if you're not using video you don't need it.
i 've got this message, after quartus 18.1 lite patching and build_all.sh in pakman folder
Error (20004): Your design targets the device family "Cyclone V". The specified family is not a valid device family, is not installed, or is not supported in this version of the Quartus Prime software. If you restored a project from an archived version, your project was successfully restored, but you still must specify or install a supported device family.
Error: Quartus Prime Analysis & Synthesis was unsuccessful. 1 error, 0 warnings
I usually used GUI for compiling. One thing that I noticed that there wasn't any lite version in project folder.
Edit:
if project don't contain _lite version then this will create new project (_lite_lite) with Cyclone V family
quartus_sh --flow compile build/$PROJECT_NAME$LITE
Edit 2:
Noticed that nios shell cp command uses different permissions and it will cause problems. after commenting out cp xxx and manually copying project folder to build it started compiling design
Edit 3:
In some "_lite_sys.qsys" files have uart blocks that will cause qsys build to fail.
I have 13.12.2018 "VidorBitstream-release.zip" from github
You can just copy paste files .qpf and .qsf and add "_lite" in the end of filename.
qpf is project file and qsf is settings file for that project.
Edit:
Add this line to _lite.qsf
set_global_assignment -name VERILOG_MACRO "FREE_VERSION=1"
Edit 2:
If there are also qsys file in project then you have to add "_lite" for QIP file. Example from mbox template
set_global_assignment -name QIP_FILE ../build/MKRVIDOR4000_template_mbox_lite_sys/synthesis/MKRVIDOR4000_template_mbox_lite_sys.qip
Hi guys,
We recently fixed a couple of issues with the lite projects so you should pull the latest changes to fix these.
Regarding Pacman you will see that it's not published yet... There's only the project but it will fail compilation as we can't publish the IP blocks (yet).
If you have the lite version of quartus you should only compile lite projects. This is done automatically if you follow our guide and use command line tools whereas in quartus ide you have to manually select the right project files.
The reason lite projects lack uart is that we used the 16550 compatible uart up which is not included in the free version of quartus so we had to remove it for the lite builds.
Importing in eclipse is a bit more complex as you have to import them as external makefile projects. Unfortunately this won't allow full functionality as the whole eclipse thing from Intel is a bit flawed.
The reason why things are different when you create your nap is simply because our settings are customized but you can get the same settings if you copy the settings.bsp file from our to your directory
