Hello.
I have a car at the moment that I'm tuning via real time on PC based software that uses a Arduino or a DLP-08 that uses Analog or Digital inputs to send to the program in real time via USB connection.
The problem I face is I want to add 3 addressed DS18b20 sensors to measure various temperature readouts on there own pin 3-4-5 and have not a clue where to start.
I have a compiled code that was kindly made by a tuner for Arduino that I would like to use on the Arduino nano board.
I have basic Arduino knowledge and if some one could help me this it would be most appreciated.
Addresses:
DeviceAddress Probe01 = { 0x28, 0xE1, 0x53, 0xD7, 0x06, 0x00, 0x00, 0x8D };
DeviceAddress Probe02 = { 0x28, 0xB3, 0x18, 0x2F, 0x06, 0x00, 0x00, 0x39 };
DeviceAddress Probe03 = { 0x28, 0x1B, 0x75, 0xC4, 0x06, 0x00, 0x00, 0xE4 };
Arduino based code:
/* Arduino One - DLP emulation */
const int DLP_CMD_DIGITAL_IN_CH1 = 0x41;
const int DLP_CMD_DIGITAL_IN_CH2 = 0x53;
const int DLP_CMD_DIGITAL_IN_CH3 = 0x44;
const int DLP_CMD_DIGITAL_IN_CH4 = 0x46;
const int DLP_CMD_DIGITAL_IN_CH5 = 0x47;
const int DLP_CMD_DIGITAL_IN_CH6 = 0x4E;
const int DLP_CMD_DIGITAL_IN_CH7 = 0x4A;
const int DLP_CMD_DIGITAL_IN_CH8 = 0x4B;
const int DLP_CMD_ANALOG_IN_CH1 = 0x5A;
const int DLP_CMD_ANALOG_IN_CH2 = 0x58;
const int DLP_CMD_ANALOG_IN_CH3 = 0x43;
const int DLP_CMD_ANALOG_IN_CH4 = 0x56;
const int DLP_CMD_ANALOG_IN_CH5 = 0x42;
const int DLP_CMD_ANALOG_IN_CH6 = 0x4E;
const int DLP_CMD_ANALOG_IN_CH7 = 0x4D;
const int DLP_CMD_ANALOG_IN_CH8 = 0x2C;
const int DLP_CMD_TEMPERATURE_IN_CH1 = 0x39;
const int DLP_CMD_TEMPERATURE_IN_CH2 = 0x30;
const int DLP_CMD_TEMPERATURE_IN_CH3 = 0x2D;
const int DLP_CMD_TEMPERATURE_IN_CH4 = 0x3D;
const int DLP_CMD_TEMPERATURE_IN_CH5 = 0x4F;
const int DLP_CMD_TEMPERATURE_IN_CH6 = 0x50;
const int DLP_CMD_TEMPERATURE_IN_CH7 = 0x5B;
const int DLP_CMD_TEMPERATURE_IN_CH8 = 0x5D;
const int DLP_SETUP_FARENHEIT = 0x4C; // not used
const int DLP_SETUP_CELCIUS = 0x3B; // not used
const int DLP_SETUP_ASCII = 0x60;
const int DLP_SETUP_BINARY = 0x5C;
const int DLP_CMD_PING = 0x27;
const int DLP_RESP_PING = 0x51;
const int SET_MODE_ASCII = 0;
const int SET_MODE_BINARY = 1;
const float AD_MULTIPLIER = 5.0/1024.0;
pinMode(A0,INPUT);
pinMode(A1,INPUT);
pinMode(A2,INPUT);
pinMode(A3,INPUT);
pinMode(A4,INPUT);
pinMode(A5,INPUT);
int rxByte = 0;
int currMode = SET_MODE_ASCII;
int sensorValue = 0;
if (Serial.available() > 0)
rxByte = Serial.read();
int sendADVal = false;
int sendTempVal = false;
switch (rxByte)
case DLP_SETUP_ASCII:
case DLP_SETUP_BINARY:
currMode = SET_MODE_BINARY;
case DLP_SETUP_FARENHEIT:
break; // not used
case DLP_SETUP_CELCIUS:
break; // not used
case DLP_CMD_PING:
// ping response
Serial.write(DLP_RESP_PING);
case DLP_CMD_ANALOG_IN_CH1:
sensorValue = analogRead(A0);
sendADVal = true;
case DLP_CMD_ANALOG_IN_CH2:
sensorValue = analogRead(A1);
sendADVal = true;
case DLP_CMD_ANALOG_IN_CH3:
sensorValue = analogRead(A2);
sendADVal = true;
case DLP_CMD_ANALOG_IN_CH4:
sensorValue = analogRead(A3);
sendADVal = true;
case DLP_CMD_ANALOG_IN_CH5:
sensorValue = analogRead(A4);
sendADVal = true;
case DLP_CMD_ANALOG_IN_CH6:
sensorValue = analogRead(A5);
sendADVal = true;
case DLP_CMD_ANALOG_IN_CH7:
case DLP_CMD_ANALOG_IN_CH8:
sensorValue = 0; // not available
sendADVal = true;
case DLP_CMD_TEMPERATURE_IN_CH1:
case DLP_CMD_TEMPERATURE_IN_CH2:
case DLP_CMD_TEMPERATURE_IN_CH3:
case DLP_CMD_TEMPERATURE_IN_CH4:
case DLP_CMD_TEMPERATURE_IN_CH5:
case DLP_CMD_TEMPERATURE_IN_CH6:
case DLP_CMD_TEMPERATURE_IN_CH7:
case DLP_CMD_TEMPERATURE_IN_CH8:
sendTempVal = true;
default:
if (sendADVal || sendTempVal)
if (currMode == SET_MODE_BINARY)
Serial.write((char)(sensorValue >> 8));
Serial.write((char)(sensorValue));
Serial.print((float)sensorValue * AD_MULTIPLIER,2);
Serial.println("V");
